Custom parsers
Important: Custom parser support for Code Connect is in preview, and the API is likely to change during this period. Please share your feedback by creating a GitHub issue.
Overview
Custom parsers allow users to add support for languages that aren't natively supported by Code Connect.
Commands
Please refer to the general documentation for more information on the available CLI commands. When using a custom parser, the CLI commands communicate with the supplied parser command to request the appropriate Code Connect docs (for publish and parse), or to create Code Connect files (for create).
Publish and Parse commands
When using a custom parser, the publish and parse commands operate on all the files specified in the includes field and excluding those in the excludes field of the figma.config.json. It then runs the parserCommand supplied in the config, passing an object of type ParseRequestPayload by stdin. The parserCommand then parses the files and generates Code Connect documents, including template code using the Template API, then outputs a return object of type ParseResponsePayload via stdout. If the publish command was chosen, then these are published to Figma.
npx figma connect publish --config figma.config.json --token <auth token>
Create
The create command fetches the specified component's definition from Figma, then invokes the parserCommand in the figma.config.json with an object of type CreateRequestPayload passed by stdin, which contains details about the components. The parser then creates any relevant Code Connect file(s), and returns an object of type CreateResponsePayload to stdout.
npx figma connect create "<url_to_node>" -config figma.config.json --token <auth token>
Config
Custom parsers must be configured in the figma.config.json. In addition to general configuration, custom parsers require the following fields:
parser: This must be set to"custom"parserCommand: This is the full path or command to invoke the parser, such as./tools/parserornode parser.jsincludes: This field is required for custom parsers and specifies what files are passed to the binary when runningparseorpublish
Example figma.config.json file
"codeConnect": {
"parser": "custom",
"parserCommand": "node ../parserDirectory/parser.js",
"include": [
"**/*.figma.test"
"exclude": [
Input
The input type for a parse request has the following structure:
export type ParseRequestPayload = {
mode: 'PARSE'
// An array of absolute paths for the parser to process, representing all
// files matched by the include/exclude globs for this parser.
paths: string[]
// Config options passed into this parser (not all parsers) from the config.
// Each parser's configuration is separate and can take any shape, though we
// will recommend using the same naming for common concepts like "importPaths".
config: Record<string, any>
The input type for a create request has the following structure:
export type CreateRequestPayload = {
mode: 'CREATE'
// Absolute destination directory for the created file. The parser is free to
// write to a different directory if appropriate (e.g. it analyses your codebase
// to identify where this component should go), but usually it should respect this.
destinationDir: string
// Optional destination file name. If omitted, the parser can determine the
// file name itself.
destinationFile?: string
// The filepath of the code to be connected. If present, this is used instead of
// component.normalizedName
sourceFilepath?: string
// The export to use from sourceFilepath (TypeScript only)
sourceExport?: string
// A mapping of how Figma props should map to code properties
propMapping?: PropMapping
// Information about the Figma component. This matches the REST API (except the
// figmaNodeUrl and normalizedName fields), which should make it easier to
// implement and maintain as we can just pass it through
component: {
// The URL of the Figma component. This field is not in the REST API but
// is added for convenience.
figmaNodeUrl: string
// The ID of the Figma component
// The name of the Figma component
// The name of the Figma component, nomalized for use in code.
// This field is not in the REST API but is added for convenience.
normalizedName: string
// The type of the Figma component
type: 'COMPONENT' | 'COMPONENT_SET'
// Map of the Figma component's properties, keyed by property name
componentPropertyDefinitions: Record<string, ComponentPropertyDefinition>
// The configuration object for this parser.
export type ComponentPropertyDefinition = {
// The property type
type: 'BOOLEAN' | 'INSTANCE_SWAP' | 'TEXT' | 'VARIANT'
// The default value of this property
defaultValue: boolean | string
// All possible values for this property. Only exists on VARIANT properties
variantOptions?: string[]
Output
The expected type for the output of the parse command is below. The template field is the Javascript that is used to render the snippet in the Code Connect panel. The API documentation can be found here.
export const ParseResponsePayload = {
// Array of Code Connect docs parsed from the input files
docs: {
// The Figma node URL the doc links to e.g. https://www.figma.com/design/123/MyFile?node-id=1-1
figmaNode: string,
// Optional component name. This is only used for display purposes
// so can be omitted if it's not relevant to the language/framework
component?: string,
// Variant restrictions keyed by Figma property name e.g. `{ 'With icon': true }`
variant?: Record<string, string>,
// Source path - a relative path to the file containing the component definition
source: string,
// Optional source location containing line number information.
sourceLocation?: {
// Optional line number to link to. This is only used if type === 'PATH',
// to generate a link to the correct line
line: number
// The JS template function to use for this doc
template: string,
templateData: {
// Map of information describing the props used by the template. This is
// used by the CLI to validate props before publishing.
props: PropMapping,
// Optional array of imports for this component. These are prepended
// to the example code.
imports?: string[],
// Whether the example should be rendered inline if it's a nested instance
nestable?: boolean,
// The language to use for syntax highlighting
// supported values can be found in the SyntaxHighlightLanguage type below
language: SyntaxHighlightLanguage,
// Label to be used for the example in the UI
label: string,
// Any info, warning or error messages generated during parsing.
messages: ParserExecutableMessages,
export const ParserExecutableMessages = {
// DEBUG and INFO messages should be output to console by the CLI for the
// user to read, according to the current log level setting.
// If any WARNING or ERROR messages are returned, the CLI can determine
// whether it should proceed with publishing or not based on configuration
// and the return code should be zero or non-zero as appropriate.
level: 'DEBUG' | 'INFO' | 'WARN' | 'ERROR',
// Optional type of message which can be displayed highlighted in the output
type?: string,
message: string,
// Optional source location which can be displayed in a standardised form
sourceLocation?: {
file: string,
line?: number,
export type PropMapping = Record<string, Intrinsic>
export type SyntaxHighlightLanguage =
| 'typescript'
| 'cpp'
| 'ruby'
| 'css'
| 'javascript'
| 'html'
| 'json'
| 'graphql'
| 'python'
| 'go'
| 'sql'
| 'swift'
| 'kotlin'
| 'rust'
| 'bash'
| 'xml'
| 'plaintext'
| 'jsx'
| 'tsx'
| 'dart'
The expected type for the output of the create command has the following structure:
export const CreateResponsePayload = {
// A list of files created, which can be output to the console
createdFiles: {
// The absolute path of the created file
filePath: string,
// Any info, warning or error messages generated during creation.
Example Template Implementation
Here's a comprehensive example showing how to implement a template using the Template API:
const figma = require('figma')
const instance = figma.selectedInstance
// Getting property values
const stringProp = instance.getString('String Prop')
const booleanProp = instance.getBoolean('Boolean Prop')
const enumProp = instance.getEnum('Enum Prop', {
'Option1': 'value1',
'Option2': 'value2'
// Finding layers
const textLayer = instance.findText('Label')
const childInstance = instance.findInstance('Icon')
const connectedInstance = instance.findConnectedInstance('button-123')
// Using selector options
const nestedText = instance.findText('Description', {
path: ['Container', 'Content'],
traverseInstances: true
// Using selector functions
const allButtons = instance.findConnectedInstances(
node => node.properties['type'] === 'button'
export default { example: figma.code`<Component
label={${stringProp}}
enabled={${booleanProp}}
variant={${enumProp}}
icon={${childInstance?.executeTemplate().example}}
/>`, id: 'example-id' }
