Template API
This reference describes the Code Connect Template API.
figma
This the core object for retrieving data and can be imported from 'figma':
import figma from 'figma'
figma.code
This function wraps the code to be rendered in the Code Connect Panel. Note the different format if you would like to pass prop data.
export default figma.code`${code}`
// format used for passing metadata e.g. making instance prop data available
export default { ...figma.code`${code}`, metadata: { __props } }\n`
figma.currentLayer: InstanceHandle
The currentLayer object represents the currently selected layer in the Figma document. This InstanceHandle provides access to various properties and methods that allow you to interact with the selected layer.
figma.properties
The properties object is a shorthand for figma.currentLayer.__properties__
InstanceHandle Object
Properties
children:
- List of direct children (instances or text).
__properties__
- returns a object of methods that give access to various properties on the figma node. See next section for available methods.
Methods
__find__(name): InstanceHandle | ErrorHandle | null
- Finds a child or nested child instance by name.
__findChildWithCriteria__({ type, name }: { type: 'INSTANCE' | 'TEXT'; name: string }): InstanceHandle | TextHandle | ErrorHandle | null
- Finds a child matching the specified type and name
__getPropertyValue__(name: string): string | boolean | ErrorHandle
- Gets a property value by name.
__render__(): ResultSection[]
- Returns the render information for the node.
- If an instance doesn't have an associated template then the below format is returned
type: 'INSTANCE' as const,
guid,
symbolId,
__getProps__(): Record<string, any> | ErrorHandle | undefined
- Returns the properties specified in the metadata field
__renderWithFn__(renderFn: (props: Record<string, any>) => TemplateStringResult): ResultSection[] | ErrorHandle | undefined
- Renders with a provided function.
properties or __properties__
The properties object provides several methods to interact with the properties of the current node.
boolean(propertyName: string, options?: Record<string, TemplateArgValueKind> ): boolean
This method returns the boolean value of the specified property of the layer. You can specify options to provide a mapping from a value (true/false) to anything of TemplateArgValueKind.
An example is
const booleanProperty = figma.currentLayer.__properties__.boolean("propertyName", {
"true": 'icon',
"false": undefined });
enum(propertyName: string, options: Record<string, TemplateArgValueKind> ): number
This method returns the enum value of the specified property of the layer. The keys in this options object should match the different options of that Variant in Figma, and the value is whatever you want to output instead which is of type TemplateArgValueKind.
string(propertyName: string): string
This method returns the string value of the specified property of the layer.
instance(propertyName: string): string | ResultSection[]
This method returns the rendered instance that is mapped to the instance-swap property of propertyName. This method returns the rendered instance (i.e. render() is called on it)
__instance__(instanceSwapProp: string): InstanceHandle | undefined
This method returns the instance that is mapped to the instance-swap property of propertyName. Unlike the method above, this does not call render() .
children(layerNames: string[]): ResultSection[]
This method gets any children with names in the layerNames, calls render() on them and returns this array.
Example Usage
const string = figma.currentLayer.__properties__.string('String Prop')
const boolean = figma.currentLayer.__properties__.boolean('Boolean Prop')
const instance = figma.currentLayer.__properties__.instance('Instance Prop')
const children = figma.currentLayer.__properties__.children(["Logic Child","Child 1","Child 2"])
export default figma.code`<Component
string={${string}}
boolean={${boolean}}
instance={${instance}}
children={${figma.code`${children}`}} />`
Using functions to encapsulate logic
To cover different types, you can include functions. Below is an example of what a complex parsed React Code Connect doc looks like.
function _fcc_renderProp(name, prop) {
if (Array.isArray(prop)) {
return figma.code` ${name}={<>${prop}</>}`
if (typeof prop === 'boolean') {
return prop ? ` ${name}` : ''
// Replace any newlines or quotes in the string with escaped versions
if (typeof prop === 'string') {
const str = prop.replaceAll('\n', '\\n').replaceAll('"', '\\"')
if (str === '') {
return ''
return ` ${name}="${str}"`
if (typeof prop === 'number') {
return ` ${name}={${prop}}`
if (prop === undefined) {
return ''
return ''
function _fcc_renderChildren(prop) {
return prop
if (typeof prop === 'string' || typeof prop === 'number' || typeof prop === 'boolean') {
return prop
return ''
const enumProp = figma.currentLayer.__properties__.enum('Enum Prop', {
"String": 'String',
"Number": 3,
"Boolean true": true,
"Boolean false": false,
"Undefined": undefined,
"figma.string": figma.currentLayer.__properties__.string('String Prop'),
"figma.boolean": figma.currentLayer.__properties__.boolean('Boolean Prop'),
"figma.instance": figma.currentLayer.__properties__.instance('Instance Prop'),
"figma.children": figma.currentLayer.__properties__.children(["Logic Child","Child 1","Child 2"])})
export default figma.code`<TestComponent
${_fcc_renderProp('boolean', boolean)}${_fcc_renderProp('instance', instance)}${_fcc_renderProp('childrenProp', children)}${_fcc_renderProp('enum', enumProp)}>
<div className="string">${_fcc_renderChildren(string)}</div>
<div className="boolean">${_fcc_renderChildren(boolean)}</div>
<div className="instance">${_fcc_renderChildren(instance)}</div>
<div className="children">${_fcc_renderChildren(children)}</div>
<div className="enum">${_fcc_renderChildren(enumProp)}</div>
</TestComponent>`
Object types
* Represents a section of code, which can be rendered verbatim
type CodeSection = {
type: 'CODE'
code: string
* Represents a child instance, which should be rendered as a pill or resolved
* and evaluated by the UI
type InstanceSection = {
type: 'INSTANCE'
/** The guid of the instance layer */
guid: string
/** The guid of the backing component */
symbolId: string
/** Represents an error that occurred during template execution */
type ErrorSection = {
type: 'ERROR'
message: string
errorObject?: ResultError
export type ResultSection = CodeSection | InstanceSection | ErrorSection
export type SectionsResult = {
result: 'SUCCESS'
data: {
type: 'SECTIONS'
sections: ResultSection[]
language: string
metadata?: {
__props: Record<string, any>
[key: string]: any
export type TemplateArgValueKind =
| string
| boolean
| ResultSection[]
| undefined
export type TemplateStringResult = SectionsResult['data']
export type PropertyNotFoundErrorObject = {
type: 'PROPERTY_NOT_FOUND'
export type ChildLayerNotFoundErrorObject = {
type: 'CHILD_LAYER_NOT_FOUND'
layerName: string
type PropertyTypeMismatchErrorObject = {
type: 'PROPERTY_TYPE_MISMATCH'
expectedType: string
type TemplateExecutionErrorObject = {
type: 'TEMPLATE_EXECUTION_ERROR'
export type ResultError =
