Editing Properties
In many cases, editing a node property is as straightforward as changing a property on a regular node object. For example, this is how you could move a node 10 pixels to the right:
node.x += 10 // easy!
However, for more complex properties that are stored as arrays and objects, you will notice that we marked all the properties in those objects as readonly. That means that the following, which you may naturally be inclined to try, won't work:
// error: object is not extensible
figma.currentPage.selection.push(otherNode)
// error: Cannot assign to read only property 'r' of object
node.fills[0].color.r = 10
In Figma design's Dev Mode, plugins can only edit certain node metadata, such as pluginData, relaunchData, and exportAsync().
Learn more in the Working in Dev Mode → guide.
The 'How'
For all node properties, making a change to a property requires setting the entire property. Often, this will mean making a copy of the original property, which can then be modified.
For arrays of nodes like selection where you want to make a copy of the array, but not the nodes themselves, an easy way to make a copy of the array is to use array.slice(). Other array methods that return a new array include array.concat() and array.map(). Keep in mind that most array methods such as array.push() do not create a new array, though they may be used on a copy of the array.
Example:
// Example 1: Adding a new element to the selection via `concat`
figma.currentPage.selection = figma.currentPage.selection.concat(someNode)
// Example 2: Adding a new element to the selection via `slice`
const selection = figma.currentPage.selection.slice()
selection.push(someNode)
figma.currentPage.selection = selection
// Creating a new selection. This is more efficient
// than editing `page.selection` repeatedly.
const newSelection = []
newSelection.push(...)
figma.currentPage.selection = newSelection
// Remove element in selection at index i
selection.splice(i, 1)
For objects such as fills/paints, you'll want to do something similar, which is to clone the object.
// Example: Changing the red channel of the first fill
const fills = clone(rect.fills)
fills[0].color.r = 0.5
rect.fills = fills
For more detail on changing color properties, see the Changing Colors section below.
There's many ways to implement such a clone function. A simple though inefficient one-liner would be:
function clone(val) {
return JSON.parse(JSON.stringify(val))
A perhaps more principled way of cloning would look like:
const type = typeof val
if (val === null) {
return null
} else if (type === 'undefined' || type === 'number' ||
type === 'string' || type === 'boolean') {
return val
} else if (type === 'object') {
if (val instanceof Array) {
return val.map(x => clone(x))
} else if (val instanceof Uint8Array) {
return new Uint8Array(val)
} else {
let o = {}
for (const key in val) {
o[key] = clone(val[key])
return o
throw 'unknown'
Changing colors
A common use case is to modify a node fill with a solid color. Color objects in the Plugin API use separate numeric properties for each color channel, but you can use figma.util.solidPaint to set both color and opacity using familiar CSS string encodings:
if (fills[0].type === 'SOLID') {
fills[0] = figma.util.solidPaint("#FF00FF88", fills[0])
rect.fills = fills
For setting colors on other types of API objects, see figma.util.rgb and figma.util.rgba.
The 'Why'
Bonus material, entirely optional
For your curiosity, properties work this way to defend you against easy mistakes while working around some limitations of JavaScript.
This way of editing properties is not our #1 choice of API design, but...
- When writing
color = node.fills[0].color, thecolorobject has to be either a copy or a merely view into the source-of-truth that we store internally. We can't expose the internal one because:
- Of stability reasons
- In some cases, the internal one has a more complex structure that we simplified for the API
- Many things have to happen inside Figma when a property is changed (e.g. re-render, update instances)
- The real
colorisn't even a JavaScript object, but somewhere in WebAssembly memory
Example:
// This wouldn't do anything, which is even more
// confusing, so we throw an exception
node.fills.[0].color.r = 0.5
In the above example, setting a property on a plain JS object can't notify Figma of changes.
- We could have properties like
node.fillsreturn magic objects that can notify Figma of changes using getter, setters, or even proxies. However, that would require us to re-implement JavaScript arrays, which is not advisable. It also leads to other confusing situations:
// just a plain array
let selection = [A, B, C]
// converts plain array into magic array?
// doesn't do anything, still a plain array
selection.push(D)
In addition, due to the need to pass plain objects when message-passing between the main thread and the UI, the magic objects would have to be converted back and forth to plain objects anyway.
Debugging via console.log would also be quite painful. Since getters & setters have to be evaluated, everything would always appear as (...) in the console that you would need to click to expand. Whereas currently, console.log(node.fills) prints out the entire fills object correctly.
In the end, while magic objects would be convenient in some cases, they are only convenient if they look as much like normal objects as possible. But if they did, it would be hard to tell the two apart. Since it wouldn't be possible to fully hide the abstraction, the abstraction would fail in random, hard to predict ways.
Note: node objects are magic objects with getters & setters, because they have to be. But there's a big difference between having a magic object and a magic object whose properties recursively return magic objects.
