Making Network Requests
This guide describes how to make basic network requests, test network access, and specify the scope of your widget's network access. As a best practice, Figma recommends that your widget only allows domains that are needed for your widget to work.
In practice, you first develop your widget and implement all the required network requests. Then, before publishing, you can use the instructions in this guide to specify access to only the domains used by your widget.
Make network requests
Making network requests with widgets is very similar to making network requests with plugins. The widget approach uses the Plugin API, and so has the same requirements and limitations as other uses of the Plugin API.
This guide assumes that you’re familiar with the basics of creating Figma widgets. If you’re new to developing plugins and widgets, check out the Build your first plugin course — you can copy and paste the code from this guide into widgets you build.
The following code sample creates an element that, when clicked, uses the Fetch API to make a request. The response is then rendered in a new text node.
const { widget } = figma;
const { Text } = widget;
// This widget fetches a resource and renders the text response in a rectangle.
function Widget() {
return (
<Text
fontSize={24}
onClick={
(async () => {
const response = await fetch('https://httpbin.org/get?success=true')
const json = await response.json()
const textNode = figma.createText()
// Make sure the new text node is visible where we're currently looking
textNode.x = figma.viewport.center.x
textNode.y = figma.viewport.center.y
await figma.loadFontAsync(textNode.fontName as FontName)
// success=true!
textNode.characters = JSON.stringify(json.args, null, 2)
figma.closePlugin()
Show fetch response
</Text>
widget.register(Widget);
Because widgets run inside a browser environment, Cross-Origin Resource Sharing policies apply. Widget iframes have a null origin. This means that they will only be able to call APIs with Access-Control-Allow-Origin: * (i.e., those that allow access from any origin).
Previously, to make network requests within a widget, you had to implement an iframe to handle sending requests and receiving data. While widgets implemented this way will continue to function normally and do not need to be modified, we recommend using the simpler Fetch API approach. The Fetch API is provided by the Plugin API, which can be used with your widgets.
Test network access
After you've implemented network requests in your widget, whether calls to an API or getting images from a server, test the impact of limiting your widget's network access. Then, use the results of your testing to build the list of domains you need to appropriately limit network access.
To test the impact of limiting your widget's network access:
In your widget's
manifest.json, add thenetworkAccesskey with theallowedDomainsproperty set to["none"].Manifest.json{
"name": "MyWidget",
"id": "737805260747778093",
"api": "1.0.0",
"widgetApi": "1.0.0",
"editorType": ["figma", "figjam"],
"containsWidget": true,
"main": "code.js",
"ui": "ui.html",
"networkAccess": {
"allowedDomains": ["none"]
In Figma, try to use your widget as normal. In the developer console, note any content-security policy (CSP) errors. For example, if the request in Make network requests was blocked:
CSP errorRefused to connect to 'https://httpsbin.org/' because it violates the following Content Security Policy directive: "default-src data:".
Note that 'connect-src' was not explicitly set, so 'default-src' is used as a fallback. -
As you identify CSP errors, follow the Limit network access steps to remove
"none"and add the domains that your widget requires to theallowedDomainslist.
When you're confident that all the required domains are listed in allowedDomains and you no longer encounter CSP errors, testing is complete.
Specify network access
To specify a list of domains that your widget is allowed to access, you update the widget's manifest.json file:
In your widget's
manifest.json, add thenetworkAccesskey.networkAccesshas the following properties:allowedDomains,reasoning, anddevAllowedDomains.Manifest.json{
"name": "MyWidget",
"api": "1.0.0",
"main": "code.js",
"ui": "ui.html",
"networkAccess": {
"allowedDomains": [],
"reasoning": "",
"devAllowedDomains": []
Add domains to the
allowedDomainslist. The domains that you add to the list should correspond to the domains that you are making requests to. This includes any requests you make for external resources using methods like createImageAsnyc().For example, to limit a widget's access to only the
httpbin.orgdomain used in Make network requests:Manifest.json{
"name": "MyWidget",
"api": "1.0.0",
"main": "code.js",
"ui": "ui.html",
"networkAccess": {
"allowedDomains": ["httpbin.org"],
"reasoning": "",
}If the only endpoint the widget uses is
/get, make the string in theallowedDomainslist even more granular:Manifest.json{
"name": "MyWidget",
"api": "1.0.0",
"main": "code.js",
"ui": "ui.html",
"networkAccess": {
"allowedDomains": ["httpbin.org/get"],
"reasoning": "",
}This way, no unexpected requests can be made to other endpoints on the domain.
noteThere are several patterns that can be used to specify domains for
allowedDomains. For a complete list, see Widget Manifest. You can also specify:-
["none"]:noneis a special keyword that prevents all network access. Use this if your widget doesn't make any network requests. -
["*"]:*is a special character that permits your widget to access any domain. If your widget includes*inallowedDomains, thenreasoningis required.
For
reasoning, provide a brief explanation for the access scope permitted byallowedDomains. When you publish your widget, this explanation is visible on your widget's Community page along with the list of allowed domains.For example:
Manifest.json{
"name": "MyWidget",
"api": "1.0.0",
"main": "code.js",
"ui": "ui.html",
"networkAccess": {
"reasoning": "MyPlugin queries httpbin.org/get for example responses.",
If you need to access a local or development web server to build your widget, add its domain(s) to the
devAllowedDomainslist. The domains that you add to the list should correspond to the local URL(s) for your development server. If you want to access a local or development web server inallowedDomains, thenreasoningis required.For example:
Manifest.json{
"name": "MyPlugin",
"id": "737805260747778092",
"api": "1.0.0",
"main": "code.js",
"ui": "ui.html",
"networkAccess": {
"devAllowedDomains": ["http://localhost:3000"]
Save the changes to your manifest.
After networkAccess is implemented, Figma enforces the list of domains that you gave for allowedDomains. If a request originates from your widget to a domain not in allowedDomains, Figma blocks the request and throws a content-security policy (CSP) error.
For example, if our widget attempts to make a request to httpbin.org/post, we get the following error:
Refused to connect to 'https://httpbin.org/post' because it violates the following Content Security Policy directive: "default-src data:". Note that 'connect-src' was not explicitly set, so 'default-src' is used as a fallback.
