Working with Lists
In some cases, you might want to render a list of values. For example, you might have a list of user photo urls that you want to render.
A common pattern to achieve this in JSX is to use a map as follows:
Rendering a list with map()
const { widget } = figma
const { AutoLayout, Image } = widget
const userPhotoUrls = [
"https://....",
"https://....",
"https://....",
function ListExample() {
return (
<AutoLayout>
{userPhotoUrls.map(url => {
return <Image key={url} src={url} />
</AutoLayout>
widget.register(ListExample);
You might notice that we’ve also specified a key prop on each image! This works very much in the same way as the key prop in React and it used as a hint to help us identify which items have changed/ been added/removed across re-renders to improve the performance of re-rendering these items!
caution
⚠️ We’ll warn against missing key props in the console whenever we detect lists of children without specified keys. You can fix these warnings by giving each element inside an array a key!
