Known issues with MCP clients
Known issues you might encounter when using MCP clients with the Figma MCP server and how to resolve them.
Claude Code token limit exceeded error
Problem: You receive an error message like this when using Claude:
Error: MCP tool "get_code" response (351378 tokens) exceeds maximum allowed tokens (25000).
Please use pagination, filtering, or limit parameters to reduce the response size.
Why this happens: The response from the Figma MCP server contains more tokens than your AI assistant can handle in a single response.
Solution: Increase the maximum token limit by setting the MAX_MCP_OUTPUT_TOKENS environment variable:
  1. Open your Claude Code settings
  2. Navigate to the Environment Variables section
  3. Add or update the MAX_MCP_OUTPUT_TOKENS variable with a higher value (e.g., 50000 or 100000)
  4. Restart Claude Code for the changes to take effect
For detailed instructions, see the Claude Code environment variables documentation.
Cursor tool call failures
Problem: MCP tool calls fail unexpectedly in Cursor
Why this happens: This is often due to expired or corrupted authentication tokens.
Solution: Clear and re-authenticate your tokens:
  1. Open the Command Palette in Cursor (Cmd+Shift+P on Mac, Ctrl+Shift+P on Windows/Linux)
  2. Type and select "Clear All MCP Tokens"
  3. Follow the prompts to re-authenticate with your accounts
  4. Try your MCP tool calls again
tip
If you continue experiencing issues, try restarting Cursor completely after clearing tokens and re-authenticating.
