Skill: create_new_file — Create a New Figma File
You can install this skill as a plugin for Claude Code or Cursor from our GitHub repository at github.com/figma/mcp-server-guide.
Use the create_new_file MCP tool to create a new blank Figma file in the user's drafts folder. This is typically used before use_figma when you need a fresh file to work with.
Skill Arguments
This skill accepts optional arguments: /figma-create-new-file [editorType] [fileName]
- editorType:
design(default) orfigjam - fileName: Name for the new file (defaults to "Untitled")
Examples:
/figma-create-new-file— creates a design file named "Untitled"/figma-create-new-file figjam My Whiteboard— creates a FigJam file named "My Whiteboard"/figma-create-new-file design My New Design— creates a design file named "My New Design"
Parse the arguments from the skill invocation. If editorType is not provided, default to "design". If fileName is not provided, default to "Untitled".
Workflow
Step 1: Resolve the planKey
The create_new_file tool requires a planKey parameter. Follow this decision tree:
User already provided a planKey (e.g. from a previous
whoamicall or in their prompt) → use it directly, skip to Step 2. -
No planKey available → call the
whoamitool. The response contains aplansarray. Each plan has akey,name,seat, andtier.- Single plan: use its
keyfield automatically. - Multiple plans: ask the user which team or organization they want to create the file in, then use the corresponding plan's
key.
Step 2: Call create_new_file
Call the create_new_file tool with:
| Parameter | Required | Description |
planKey | Yes | The plan key from Step 1 |
fileName | Yes | Name for the new file |
editorType | Yes | "design" or "figjam" |
Example:
"planKey": "team:123456",
"fileName": "My New Design",
"editorType": "design"
Step 3: Use the result
The tool returns:
file_key— the key of the newly created filefile_url— a direct URL to open the file in Figma
Use the file_key for subsequent tool calls like use_figma.
Important Notes
- The file is created in the user's drafts folder for the selected plan.
- Only
"design"and"figjam"editor types are supported. - If
use_figmais your next step, load thefigma-useskill before calling it.
