Skill: Implement Design
You can install this skill as a plugin for Claude Code or Cursor from our GitHub repository at github.com/figma/mcp-server-guide.
Overview
This skill provides a structured workflow for translating Figma designs into production-ready code with pixel-perfect accuracy. It ensures consistent integration with the Figma MCP server, proper use of design tokens, and 1:1 visual parity with designs.
Prerequisites
- Figma MCP server must be connected and accessible
- Before proceeding, verify the Figma MCP server is connected by checking if Figma MCP tools (e.g.,
get_design_context) are available. - If the tools are not available, the Figma MCP server may not be enabled. Guide the user to enable the Figma MCP server that is included with the plugin. They may need to restart their MCP client afterward.
- User must provide a Figma URL in the format:
https://figma.com/design/:fileKey/:fileName?node-id=1-2:fileKeyis the file key1-2is the node ID (the specific component or frame to implement)
- Project should have an established design system or component library (preferred)
Required Workflow
Follow these steps in order. Do not skip steps.
Step 1: Get Node ID
Option A: Parse from Figma URL
When the user provides a Figma URL, extract the file key and node ID to pass as arguments to MCP tools.
URL format: https://figma.com/design/:fileKey/:fileName?node-id=1-2
Extract:
- File key:
:fileKey(the segment after/design/) - Node ID:
1-2(the value of thenode-idquery parameter)
Example:
- URL:
https://figma.com/design/kL9xQn2VwM8pYrTb4ZcHjF/DesignSystem?node-id=42-15 - File key:
kL9xQn2VwM8pYrTb4ZcHjF - Node ID:
42-15
Step 2: Fetch Design Context
Run get_design_context with the extracted file key and node ID.
get_design_context(fileKey=":fileKey", nodeId="1-2")
This provides the structured data including:
- Layout properties (Auto Layout, constraints, sizing)
- Typography specifications
- Color values and design tokens
- Component structure and variants
- Spacing and padding values
If the response is too large or truncated:
- Run
get_metadata(fileKey=":fileKey", nodeId="1-2")to get the high-level node map - Identify the specific child nodes needed from the metadata
- Fetch individual child nodes with
get_design_context(fileKey=":fileKey", nodeId=":childNodeId")
Step 3: Capture Visual Reference
Run get_screenshot with the same file key and node ID for a visual reference.
get_screenshot(fileKey=":fileKey", nodeId="1-2")
This screenshot serves as the source of truth for visual validation. Keep it accessible throughout implementation.
Step 4: Download Required Assets
Download any assets (images, icons, SVGs) returned by the Figma MCP server.
IMPORTANT: Follow these asset rules:
- If the Figma MCP server returns a
localhostsource for an image or SVG, use that source directly - DO NOT import or add new icon packages - all assets should come from the Figma payload
- DO NOT use or create placeholders if a
localhostsource is provided - Assets are served through the Figma MCP server's built-in assets endpoint
Step 5: Translate to Project Conventions
Translate the Figma output into this project's framework, styles, and conventions.
Key principles:
- Treat the Figma MCP output (typically React + Tailwind) as a representation of design and behavior, not as final code style
- Replace Tailwind utility classes with the project's preferred utilities or design system tokens
- Reuse existing components (buttons, inputs, typography, icon wrappers) instead of duplicating functionality
- Use the project's color system, typography scale, and spacing tokens consistently
- Respect existing routing, state management, and data-fetch patterns
Step 6: Achieve 1:1 Visual Parity
Strive for pixel-perfect visual parity with the Figma design.
Guidelines:
- Prioritize Figma fidelity to match designs exactly
- Avoid hardcoded values - use design tokens from Figma where available
- When conflicts arise between design system tokens and Figma specs, prefer design system tokens but adjust spacing or sizes minimally to match visuals
- Follow WCAG requirements for accessibility
- Add component documentation as needed
Step 7: Validate Against Figma
Before marking complete, validate the final UI against the Figma screenshot.
Validation checklist:
- Layout matches (spacing, alignment, sizing)
- Typography matches (font, size, weight, line height)
- Colors match exactly
- Interactive states work as designed (hover, active, disabled)
- Responsive behavior follows Figma constraints
- Assets render correctly
- Accessibility standards met
Implementation Rules
Component Organization
- Place UI components in the project's designated design system directory
- Follow the project's component naming conventions
- Avoid inline styles unless truly necessary for dynamic values
Design System Integration
- ALWAYS use components from the project's design system when possible
- Map Figma design tokens to project design tokens
- When a matching component exists, extend it rather than creating a new one
- Document any new components added to the design system
Code Quality
- Avoid hardcoded values - extract to constants or design tokens
- Keep components composable and reusable
- Add TypeScript types for component props
- Include JSDoc comments for exported components
Examples
Example 1: Implementing a Button Component
User says: "Implement this Figma button component: https://figma.com/design/kL9xQn2VwM8pYrTb4ZcHjF/DesignSystem?node-id=42-15"
Actions:
- Parse URL to extract fileKey=
kL9xQn2VwM8pYrTb4ZcHjFand nodeId=42-15 - Run
get_design_context(fileKey="kL9xQn2VwM8pYrTb4ZcHjF", nodeId="42-15") - Run
get_screenshot(fileKey="kL9xQn2VwM8pYrTb4ZcHjF", nodeId="42-15")for visual reference - Download any button icons from the assets endpoint
- Check if project has existing button component
- If yes, extend it with new variant; if no, create new component using project conventions
- Map Figma colors to project design tokens (e.g.,
primary-500,primary-hover) - Validate against screenshot for padding, border radius, typography
Result: Button component matching Figma design, integrated with project design system.
Example 2: Building a Dashboard Layout
User says: "Build this dashboard: https://figma.com/design/pR8mNv5KqXzGwY2JtCfL4D/Dashboard?node-id=10-5"
Actions:
pR8mNv5KqXzGwY2JtCfL4Dand nodeId=10-5 - Run
get_metadata(fileKey="pR8mNv5KqXzGwY2JtCfL4D", nodeId="10-5")to understand the page structure - Identify main sections from metadata (header, sidebar, content area, cards) and their child node IDs
- Run
get_design_context(fileKey="pR8mNv5KqXzGwY2JtCfL4D", nodeId=":childNodeId")for each major section - Run
get_screenshot(fileKey="pR8mNv5KqXzGwY2JtCfL4D", nodeId="10-5")for the full page - Download all assets (logos, icons, charts)
- Build layout using project's layout primitives
- Implement each section using existing components where possible
- Validate responsive behavior against Figma constraints
Result: Complete dashboard matching Figma design with responsive layout.
Best Practices
Always Start with Context
Never implement based on assumptions. Always fetch get_design_context and get_screenshot first.
Incremental Validation
Validate frequently during implementation, not just at the end. This catches issues early.
Document Deviations
If you must deviate from the Figma design (e.g., for accessibility or technical constraints), document why in code comments.
Reuse Over Recreation
Always check for existing components before creating new ones. Consistency across the codebase is more important than exact Figma replication.
Design System First
When in doubt, prefer the project's design system patterns over literal Figma translation.
Common Issues and Solutions
Issue: Figma output is truncated
Cause: The design is too complex or has too many nested layers to return in a single response.
Solution: Use get_metadata to get the node structure, then fetch specific nodes individually with get_design_context.
Issue: Design doesn't match after implementation
Cause: Visual discrepancies between the implemented code and the original Figma design. Solution: Compare side-by-side with the screenshot from Step 3. Check spacing, colors, and typography values in the design context data.
Issue: Assets not loading
Cause: The Figma MCP server's assets endpoint is not accessible or the URLs are being modified.
Solution: Verify the Figma MCP server's assets endpoint is accessible. The server serves assets at localhost URLs. Use these directly without modification.
Issue: Design token values differ from Figma
Cause: The project's design system tokens have different values than those specified in the Figma design. Solution: When project tokens differ from Figma values, prefer project tokens for consistency but adjust spacing/sizing to maintain visual fidelity.
Understanding Design Implementation
The Figma implementation workflow establishes a reliable process for translating designs to code:
For designers: Confidence that implementations will match their designs with pixel-perfect accuracy. For developers: A structured approach that eliminates guesswork and reduces back-and-forth revisions. For teams: Consistent, high-quality implementations that maintain design system integrity.
By following this workflow, you ensure that every Figma design is implemented with the same level of care and attention to detail.
