Tools and prompts
The Figma MCP server provides the following tools:
generate_figma_design(specific clients only, remote only): Generates design layers from interfacesget_design_context: Get the design context for a layer or selectionget_variable_defs: Returns the variables and styles used in your Figma selectionget_code_connect_map: Retrieves a mapping between Figma node IDs and their corresponding code components in your codebaseadd_code_connect_map: Adds a mapping between a Figma node ID and its corresponding code component in your codebaseget_screenshot: Allows the agent to take a screenshot of your selectioncreate_design_system_rules: Creates a rule file that provide agents with the right context to translate designs into frontend codeget_metadata: Returns a sparse XML representation of your selection that contains basic properties such as layer IDs, names, types, position and sizesget_figjam: Converts FigJam diagrams (such as app architecture workflows) to XMLgenerate_diagram: Generates a FigJam diagram from Mermaid syntaxwhoami(remote only): Returns the identity of the user that's authenticated to Figmaget_code_connect_suggestions: A Figma-prompted tool call to find suggestions for mapping Figma node IDs to their corresponding code components in your codebase using Code Connectsend_code_connect_mappings: A Figma-prompted tool used after callingget_code_connect_suggestionsto confirm the suggested Code Connect mappingsuse_figma: The general-purpose tool for creating, editing, or inspecting any object in a Figma filesearch_design_system: Searches design libraries for components, variables, and styles matching a text querycreate_new_file: Creates a new blank Figma Design or FigJam file in the authenticated user's drafts
generate_figma_design (remote only)
Note:
- For use with select MCP clients.
- Remote Figma MCP server only.
- This tool is exempt from the standard rate limits for the Figma MCP server.
Supported file types: Figma Design
For detailed instructions, see Code to canvas.
generate_figma_design lets you prompt your MCP client to send live UI for your web apps and sites as design layers to:
- New Figma Design files
- Existing Figma Design files
- Your clipboard
generate_figma_design respects your seat type when creating or editing files. New files are created in your team or organization drafts. For existing files, you must have edit permissions for the file.
get_design_context
Supported file types: Figma Design, Figma Make
Use the MCP server to get the design context for a layer or your selection in Figma. By default, the output is React + Tailwind, but you can customize it through your prompt.
Suggested prompts:
- Change the framework
generate my Figma selection in Vuegenerate my Figma selection in plain HTML + CSSgenerate my Figma selection in iOS
- Use your components
generate my Figma selection using components from src/components/ui- *Tip: set up Code Connect for best code reuse results. Code Connect lets you set up multiple connections per Figma Library. You can map, for example, both your React and SwiftUI code to your Figma components. The Desktop MCP server will use the Code Connect mapping you have selected in Dev Mode. To control which Code Connect mappings are sent via the Remote MCP Server, instruct your agent to set the
clientFrameworkstool call paramater to the exact Code Connect label you have set up for your mappings, e.g..React,SwiftUI.
- Combine both
generate my Figma selection using components from src/ui and style with Tailwind
Note: Selection-based prompting only works with the desktop MCP server. The remote server requires a link to a frame or layer to extract context.
get_variable_defs
Returns the variables and styles used in your Figma selection (such as colors, spacing, typography).
You can ask it to:
- List all tokens used
get the variables used in my Figma selection
- Focus on a specific type
what color and spacing variables are used in my Figma selection?
- Get both names and values
list the variable names and their values used in my Figma selection
Retrieves a mapping between Figma node IDs and their corresponding code components in your codebase. Specifically, it returns an object where each key is a Figma node ID, and the value contains:
codeConnectSrc: The location of the component in your codebase (e.g., a file path or URL).codeConnectName: The name of the component in your codebase.
This mapping is used to connect Figma design elements directly to their React (or other framework) implementations, enabling seamless design-to-code workflows and ensuring that the correct components are used for each part of the design. If a Figma node is connected to a code component, this function helps you identify and use the exact component in your project.
Adds a mapping between a Figma node ID and its corresponding code component in your codebase. Setting up these mappings will improve the output quality of design-to-code worksflows and help you identify and use the exact component in your project.
get_screenshot
Supported file types: Figma Design, FigJam
Allows the agent to take a screenshot of your selection. This helps preserve layout fidelity in the generated code. Recommended to keep on (only turn off if you're concerned about token limits).
Supported file types: No file context required
A tool for creating a rule file that provide agents with the right context to translate designs into high-quality, codebase-aware frontend code. It helps ensure alignment with your design system and tech stack, improving the relevance and accuracy of generated output.
Run this tool and make sure the result is saved to the correct rules/ or instructions/ path so your agent can access it during code generation.
get_metadata
Returns a sparse XML representation of your selection containing just basic properties such as the layer IDs, names, types, position and sizes. This is an outline that your Agent can then break down and call get_design_context on to retrieve only the styling information of the design it needs. Useful for very large designs where get_design_context produces output with a large context size. It also works with multiple selections or the whole page if you don't select anything.
get_figjam
Supported file types: FigJam
This tool returns metadata for FigJam diagrams in XML format, similar to get_metadata. In addition to returning basic properties like layer IDs, names, types, positions, and sizes, it also includes screenshots of the nodes.
generate_diagram
Generates a FigJam diagram from Mermaid syntax. This tool accepts Mermaid diagram definitions and converts them into interactive FigJam diagrams that can be edited and shared.
You do not have to provide Mermaid syntax yourself. Instead, you can prompt the agent to create diagrams by describing the desired diagram in natural language. The agent will then generate the appropriate Mermaid syntax and use the generate_diagram tool to create the FigJam diagram.
To ensure that the agent uses the Figma MCP generate_diagram tool, you can include the directive "Use the Figma MCP generate_diagram tool" in your prompt. However, the agent will likely use the tool automatically when it determines that a diagram is needed based on your request.
Supported diagram types:
- Flowchart
- Gantt chart
- State diagram
- Sequence diagram
Suggested prompts:
- Generate a diagram from a description
create a flowchart for the user authentication flow using the Figma MCP generate_diagram toolgenerate a gantt chart for the project timeline using the Figma MCP generate_diagram toolgenerate a sequence diagram for the payment processing system using the Figma MCP generate_diagram tool
- Convert existing Mermaid syntax
create a diagram from this mermaid syntax: ...
whoami (remote only)
This tool returns the identity of the user that's authenticated to Figma, including:
- The user's email address
- All of the plans the user belongs to
- The seat type the user has on each plan
A tool call prompted by Figma to detect and suggest mappings of Figma components to code components in your codebase using Code Connect.
A tool call prompted by Figma to confirm the Code Connect mappings after calling get_code_connect_suggestions.
use_figma
Note: We're quickly improving how Figma supports AI agents. This will eventually be a usage-based paid feature, but is currently available for free during the beta period.
The general-purpose tool for writing to Figma. Use it to create, edit, delete, or inspect any object in a Figma file: pages, frames, components, variants, variables, styles, text, images, and more.
When relevant, the agent will first check your design system for existing components to reuse before creating anything from scratch.
The use_figma tool is best invoked with the figma-use skill.
You can ask it to:
- Create or modify designs
add a new frame to my Figma fileupdate the button component to use the correct fill color
- Set up design tokens, variables, or styles
create a color variable collection from my design tokensset up spacing tokens in my Figma file
- Build or update component and variant systems
generate variants for the card componentsync my Figma components with my latest code changes
- Fix layout or visual issues
fix the auto-layout spacing on the nav componentupdate the typography styles to match the design spec
Searches across all connected design libraries to find components, variables, and styles matching a text query. Returns matching assets so the agent can reuse existing design system elements rather than creating new ones from scratch.
You can ask it to:
- Find components
search for a button component in my design systemfind a card component I can use for this layout
- Look up tokens
search for the primary color variable in my design systemfind spacing tokens in my design libraries
- Narrow by type
search for icon styles in my design system
create_new_file
Creates a new blank Figma Design or FigJam file in your drafts folder. If you belong to multiple plans, you'll be asked which team or organization to create the file in.
You can ask it to:
- Create a new design file
create a new Figma file called "Homepage Redesign"
- Create a new FigJam file
create a new FigJam board for our project planning session
