Write effective prompts to guide the AI
  1. The MCP gives your AI assistant structured Figma data - but what it does with that depends entirely on what you ask for.
  2. What a good prompt can do:
    • Align the result with the right framework or styling system
    • Align with your codebase conventions (file structure, naming, layout)
    • Generate code in the correct file path (like src/pages, components/ui)
    • Add or modify code inside existing files instead of creating new ones
    • Follow specific layout systems (flexbox, grid, absolute)
  3. Prompt examples
    • Generate iOS SwiftUI code from the selected Figma frame
    • Implement the selected frame using Chakra UI components
    • Generate this using components from src/components/ui
    • Add this component to src/components/marketing/PricingCard.tsx
    • Implement this using our Stack layout component
The more specific your prompt, the better the output. Treat it like briefing a teammate. The clearer your intent, the more likely you'll get exactly what you need.
