Making Network Requests
This guide describes how to make basic network requests, test network access, and specify the scope of your plugin's network access. As a best practice, Figma recommends that your plugin only allows domains that are needed for your plugin to work.
In practice, you first develop your plugin and implement all the required network requests. Then, before publishing, you can use the instructions in this guide to specify access to only the domains used by your plugin.
Make network requests
To make network requests from within a plugin, such as calls to your own API or to request resources from a server, use Figma's Fetch API. The Figma Fetch API is used in a similar way to the WhatWG Fetch API that is standard in most browsers.
This guide assumes that you’re familiar with the basics of creating Figma plugins. If you’re new to developing plugins, check out the Build your first plugin course — you can copy and paste the code from this guide into the plugin you build.
The following code sample makes a request to an external API and returns the JSON response to the console.
(async () => {
const response = await fetch('https://httpbin.org/get?success=true')
const json = await response.json()
console.log(JSON.stringify(json.args, null, 2))
figma.closePlugin()
By adding a text node to the canvas, we can deliver content from the response directly into a Figma file.
(async () => {
const response = await fetch("https://httpbin.org/get?success=true");
const json = await response.json();
const textNode = figma.createText();
await figma.loadFontAsync(textNode.fontName as FontName);
// success=true!
textNode.characters = JSON.stringify(json.args, null, 2);
figma.closePlugin();
Because plugins run inside a browser environment, Cross-Origin Resource Sharing policies apply. Plugin iframes have a null origin. This means that they will only be able to call APIs with Access-Control-Allow-Origin: * (i.e., those that allow access from any origin).
Previously, to make network requests within a plugin, you had to implement an iframe to handle sending requests and receiving data. While plugins implemented this way will continue to function normally and do not need to be modified, we recommend using the simpler Fetch API approach.
Test network access
After you've implemented network requests in your plugin (e.g. calling an API or getting images from a server), test the impact of limiting your plugin's network access. Then, use the results of your testing to build the list of domains you need to appropriately limit network access.
To test the impact of limiting your plugin's network access:
In your plugin's
manifest.json, add thenetworkAccesskey with theallowedDomainsproperty set to["none"].Manifest.json{
"name": "MyPlugin",
"id": "737805260747778092",
"api": "1.0.0",
"main": "code.js",
"ui": "ui.html",
"networkAccess": {
"allowedDomains": ["none"]
In Figma, try to use your plugin as normal. In the developer console, note any content-security policy (CSP) errors. For example, if the request in Make network requests was blocked:
CSP errorRefused to connect to 'https://httpsbin.org/' because it violates the following Content Security Policy directive: "default-src data:".
Note that 'connect-src' was not explicitly set, so 'default-src' is used as a fallback. -
As you identify CSP errors, follow the Limit network access steps to remove
"none"and add the domains that your plugin requires to theallowedDomainslist.
When you're confident that all the required domains are listed in allowedDomains and you no longer encounter CSP errors, testing is complete.
Specify network access
To specify a list of domains that your plugin is allowed to access, you update the plugin's manifest.json file:
In your plugin's
manifest.json, add thenetworkAccesskey.networkAccesshas the following properties:allowedDomains,reasoning, anddevAllowedDomains.Manifest.json{
"name": "MyPlugin",
"api": "1.0.0",
"main": "code.js",
"ui": "ui.html",
"networkAccess": {
"allowedDomains": [],
"reasoning": "",
"devAllowedDomains": []
Add domains to the
allowedDomainslist. The domains that you add to the list should correspond to the domains that you are making requests to. This includes any requests you make for external resources using methods like createImageAsnyc().For example, to limit a plugin's access to only the
httpbin.orgdomain used in Make network requests:Manifest.json{
"name": "MyPlugin",
"api": "1.0.0",
"main": "code.js",
"ui": "ui.html",
"networkAccess": {
"allowedDomains": ["httpbin.org"],
"reasoning": "",
}If the only endpoint the plugin uses is
/get, make the string in theallowedDomainslist even more granular:Manifest.json{
"name": "MyPlugin",
"api": "1.0.0",
"main": "code.js",
"ui": "ui.html",
"networkAccess": {
"allowedDomains": ["httpbin.org/get"],
"reasoning": "",
}This way, no unexpected requests can be made to other endpoints on the domain.
noteThere are several patterns that can be used to specify domains for
allowedDomains. For a complete list, see Plugin Manifest. You can also specify:-
["none"]:noneis a special keyword that prevents all network access. Use this if your plugin doesn't make any network requests. -
["*"]:*is a special character that permits your plugin to access any domain. If your plugin includes*inallowedDomains, thenreasoningis required.
For
reasoning, provide a brief explanation for the access scope permitted byallowedDomains. When you publish your plugin, this explanation is visible on your plugin's Community page along with the list of allowed domains.For example:
Manifest.json{
"name": "MyPlugin",
"api": "1.0.0",
"main": "code.js",
"ui": "ui.html",
"networkAccess": {
"reasoning": "MyPlugin queries httpbin.org/get for example responses.",
If you need to access a local or development web server to build your plugin, add its domain(s) to the
devAllowedDomainslist. The domains that you add to the list should correspond to the local URL(s) for your development server. If you want to access a local or development web server inallowedDomains, thenreasoningis required.For example:
Manifest.json{
"name": "MyPlugin",
"api": "1.0.0",
"main": "code.js",
"ui": "ui.html",
"networkAccess": {
"devAllowedDomains": ["http://localhost:3000"]
Save the changes to your manifest.
After networkAccess is implemented, Figma enforces the list of domains that you gave for allowedDomains. If a request originates from your plugin to a domain not in allowedDomains, Figma blocks the request and throws a content-security policy (CSP) error.
For example, if our plugin attempts to make a request to httpbin.org/post, we get the following error:
Refused to connect to 'https://httpbin.org/post' because it violates the following Content Security Policy directive: "default-src data:". Note that 'connect-src' was not explicitly set, so 'default-src' is used as a fallback.
