Migrating Plugins to Dynamically Load Pages
In 2023, Figma started to dynamically load pages for Figma designs. Previously, when a Figma file was accessed, all pages in the document were loaded, which led to delays in loading very large or complex files. Now, pages in Figma design files are loaded only as needed. Because pages are loaded only as needed, it is no longer guaranteed that all information in a document is accessible via the Plugin API without additional requests for page data.
This transition required the deprecation of incompatible methods and addition of new dynamic loading compatible methods in the Plugin API. This guide describes how to upgrade your plugin to use these new methods.
How to upgrade your plugin
To upgrade your plugin:
- Update the type definitions.
- Install the linter.
- Update your plugin's manifest.
- Update the plugin code to use the async APIs.
To support the way Figma loads pages as needed, we’ve updated the Plugin API. TypeScript type definitions for the changes are available in our official typings.
To access these type definitions, ensure your plugin’s package.json file contains the following entry:
"devDependencies": {
"@figma/plugin-typings": "*"
Then, re-run npm install.
Install the linter
Figma provides a set of typescript-eslint rules that help identify, and in many cases automatically fix, areas of your plugin code that need to be migrated.
To install and use the linter, follow the instructions in the Usage section of the README included with the linter rules. Find the eslint-plugin-figma-plugins repository on GitHub →
Note: The linter works for TypeScript files only. If your code is written in JavaScript, you can use a regex snippet to search for code that might need to be changed to be compatible with dynamic page loading. While this isn't all-encompassing, it should make the migration process easier. This regex snippet can be used in an editor like VS Code to search through your plugin code:
((figma\.getNodeById)|(figma\.getStyleById)|(figma\.getFileThumbnailNode)|(figma\.getLocalTextStyles)|(figma\.getLocalPaintStyles)|(figma\.getLocalEffectStyles)|(figma\.getLocalGridStyles)|(figma\.variables\.getVariableById)|(figma\.variables\.getVariableCollectionById)|(figma\.variables\.getLocalVariableCollections)|(figma\.variables\.getLocalVariables)|(\.instances)|(\.consumers)|(\.mainComponent)|(\.effectStyleId =)|(\.fillStyleId =)|(\.gridStyleId =)|(\.textStyleId =)|(\.backgroundStyleId =)|(\.strokeStyleId =)|(\.setRangeTextStyleId)|(\.setRangeFillStyleId)|(\.setRangeTextStyleId)|(\.setRangeFillStyleId)|(\.setBoundVariable)|(figma\.variables\.setBoundVariableForPaint)|(createVariable))
Update your plugin’s manifest
Dynamic page loading introduces a new field to the existing manifest fields: documentAccess.
Adding "documentAccess": "dynamic-page" to your plugin’s manifest tells Figma that it does not need to preemptively load all pages in a file before running your plugin. The manifest field and value are included by default in Figma’s plugin templates, so you won’t need to worry about this step when you create new plugins. The documentAccess field is a required manifest field for plugins and must be set to dynamic-page.
manifest: {
When documentAccess is not included in the manifest, the first time a legacy plugin runs in a newly-opened file, Figma ensures all nodes, pages, and contents of the file are loaded before running the plugin. If a Figma file is very large, this load can take around 20 to 30 seconds. Only contents of the file that have not been loaded on the client will need to be loaded, so any subsequent plugin runs during the same session will be able to run immediately, as before.
Overview of changes
With dynamic page loading, several methods are no longer supported and are replaced by new async versions that will retrieve these objects if they have not been loaded on the client. If you call any of the deprecated APIs when in dynamic page loading mode, your plugin will throw.
Variables and Styles specifically are considered objects that exist outside of pages. Similar to regular nodes, before setting a variable or a style, we need to make sure that it has been loaded on the client. We achieved this by updating APIs where a StyleId, a VariableId, or a VariableCollectionId is used directly to instead use a Style, Variable, or a VariableCollection object.
Net-new methods
Deprecations and replacements
Several methods and properties have been deprecated in favor of async replacements:
- Use
figma.getFileThumbnailNodeAsync()instead offigma.getFileThumbnailNode(). - Use
figma.getLocalEffectStylesAsync()instead offigma.getLocalEffectStyles(). - Use
figma.getLocalGridStylesAsync()instead offigma.getLocalGridStyles(). - Use
figma.getLocalPaintStylesAsync()instead offigma.getLocalPaintStyles(). - Use
figma.getLocalTextStylesAsync()instead offigma.getLocalTextStyles(). - Use
figma.getNodeByIdAsync()instead offigma.getNodeById(). - Use
figma.getStyleByIdAsync()instead offigma.getStyleById(). - Use
figma.variables.getLocalVariableCollectionsAsync()instead offigma.variables.getLocalVariableCollections(). - Use
figma.variables.getLocalVariablesAsync()instead offigma.variables.getLocalVariables(). - Use
figma.variables.getVariableByIdAsync()instead offigma.variables.getVariableById(). - Use
figma.variables.getVariableCollectionByIdAsync()instead offigma.variables.getVariableCollectionById(). - Use
setRangeFillStyleIdAsync()instead ofsetRangeFillStyleId(). - Use
setRangeTextStyleIdAsync()instead ofsetRangeTextStyleId().
In some specific cases, reading node properties has been deprecated in favor of an async getter:
- Use
ComponentNode.getInstancesAsync()instead ofComponentNode.instances. - Use
getStyleConsumersAsync()instead of theconsumers. - Use
InstanceNode.getMainComponentAsync()instead ofInstanceNode.mainComponent.
In some specific cases, assigning values directly to node properties has been deprecated in favor of an async setter:
- Use
figma.setCurrentPageAsync()instead of assigning tofigma.currentPage. - Use
setEffectStyleIdAsync()instead of assigning toeffectStyleId. - Use
setFillStyleIdAsync()instead of assigning tobackgroundStyleId. - Use
setFillStyleIdAsync()instead of assigning tofillStyleId. - Use
setGridStyleIdAsync()instead of assigning togridStyleId. - Use
setReactionsAsync()instead of assigning toreactions. - Use
setStrokeStyleIdAsync()instead of assigning tostrokeStyleId. - Use
setVectorNetworkAsync()instead of assigning tovectorNetwork. - Use
TextNode.setTextStyleIdAsync()instead of assigning toTextNode.textStyleId.
If an extension's manifest contains "documentAccess": "dynamic-page", accessing any of the deprecated items listed above will throw an exception.
Method/property usage changes
If an extension's manifest contains "documentAccess": "dynamic-page", calling any of the following methods will throw an exception unless you first call figma.loadAllPagesAsync():
DocumentNode.findAll()DocumentNode.findAllWithCriteria()DocumentNode.findOne()DocumentNode.findWidgetNodesByWidgetId()
For the methods listed below, passing a string ID is now deprecated in favor of passing objects that the IDs refer to. If an extension's manifest contains "documentAccess": "dynamic-page", passing an ID will throw an exception.
figma.variables.createVariable()- Pass aVariableCollectionobject instead of a collection ID.clearExplicitVariableModeForCollection()(present on multiple node types) - Pass aVariableCollectionobject instead of a collection ID.setExplicitVariableModeForCollection()(present on multiple node types) - Pass aVariableCollectionobject instead of a collection ID.setBoundVariable()(present on multiple node types) - Pass aVariableobject instead of a variable ID.
If an extension's manifest contains "documentAccess": "dynamic-page", some properties and methods of PageNode will throw an exception unless you explicitly load the page first using PageNode.loadAsync(). These include:
PageNode.appendChild()PageNode.childrenPageNode.exportAsyncPageNode.findAll()PageNode.findAllWithCriteria()PageNode.findChild()PageNode.findChildren()PageNode.findOne()PageNode.findWidgetNodesByWidgetId()PageNode.insertChild()
Changes to events
- If an extension's' manifest contains
"documentAccess": "dynamic-page", thedocumentchangeevent will not be available unless you first callfigma.loadAllPagesAsync(). - Where possible, prefer using the
nodechangeandstylechangeevents, which do not require triggering a full-document load.
Update plugin code to use async APIs
To update your plugin code to use the async APIs, you'll generally refactor your functions to use async and await.
Examples of upgrading to async:
// Before
function extractTextContent(nodeId: string): string[] {
const node = figma.getNodeById(nodeId)
const textNodes = node.findChild(child => child.type === "TEXT")
return textNodes.map(textNode => textNode.characters)
// After
async function extractTextContent(nodeId: string): Promise<string[]> {
const node = await figma.getNodeByIdAsync(nodeId)
// Before
function getDefinitionNode(node) {
if (node.type !== "INSTANCE") {
return node
const { mainComponent } = node
return mainComponent?.parent?.type === "COMPONENT_SET"
? mainComponent?.parent
: mainComponent
// After
async function getDefinitionNode(node) {
return node
const mainComponent = await node.getMainComponentAsync()
: mainComponent
// Before
function swapFillStyles(node1, node2) {
const fill1 = node1.fillStyleId
const fill2 = node2.fillStyleId
node1.fillStyleId = fill2
node2.fillStyleId = fill1
// After
async function swapFillStyles(node1, node2) {
const fill1Id = node1.fillStyleId
const fill2Id = node2.fillStyleId
await node1.setFillStyleAsync(fill2Id)
await node2.setFillStyleAsync(fill1Id)
Change DocumentNode.find* methods
These methods currently work by searching nodes in the document. Some of them search all nodes in the entire document, others only search the children of the current node. These two types will have different requirements moving forward.
With "documentAccess": "dynamic-page", DocumentNode.find* methods that search all nodes in entire document will throw unless figma.loadAllPagesAsync() has been called explicitly in the plugin.
Plugins must call figma.loadAllPagesAsync() before calling any of the following DocumentNode.find* methods.
figma.root.findAll()figma.root.findOne()figma.root.findAllWithCriteria()
With "documentAccess": "dynamic-page", DocumentNode.find* methods that only search the children of the node (not all nodes in the document) remain the same. These methods are the following:
figma.root.findChild()figma.root.findChildren()
* Find all nodes named "Color"
// Before
const colors = figma.root.findAll(n => n.name === "Color")
// After
await figma.loadAllPagesAsync()
// This plugin counts the number of layers, ignoring instance sublayers,
// in the document.
// Before
function getNumNonInstanceChildren(node) {
let count = 0;
const toVisit = [node]
while (toVisit.length) {
const curr = toVisit.pop()
if (curr.type !== "INSTANCE") {
toVisit.push(...curr.children)
count++;
return count;
// After
async function getNumNonInstanceChildren(node) {
let count = 0;
if (curr.type === "PAGE") {
await curr.loadAsync()
count++;
return count;
Explicitly access other pages in the document
DocumentNode.children will continue to return all of the PageNodes in the file. However, before traversing into PageNode.children, plugins will have to explicitly call PageNode.loadAsync() or load the page using one of the other asynchronous methods provided. PageNode.children will throw an exception if called on a page that has not been explicitly loaded by the plugin. The loadAsync() method only exists on PageNodes as Figma loads entire pages in together.
// Before
for (const page of figma.root.children) {
console.log(`Page ${page.name} has ${page.children.length} children`)
// After
await page.loadAsync()
// This plugin counts the number of empty pages in a file
// Before
function countEmptyPages() {
let emptyPageCount = 0
const pages = DocumentNode.children
for (const page of pages) {
if (page.children.length === 0) {
emptyPageCount++
return emptyPageCount
// After
async function countEmptyPages() {
emptyPageCount++
Accessing the current page
figma.currentPage remains the same and continues to return the current page without any async operations. If you are accessing the current page using an expression like figma.root.children[x], then you will be required to call loadAsync() as described earlier. To set the current page you must use the new async setter figma.setCurrentPageAsync(PageNode). This ensures the page is loaded prior to setting it as the current page.
Listening to document change events
When documentAccess is set to "dynamic-page", the on('documentchange') event requires that you call figma.loadAllPagesAsync() before registering the callback to ensure that events from all pages are listened to.
If you wish to listen to events without loading all pages, we have added two new event APIs. To subscribe to the changes on a specific page, you can use the PageNode.on('nodechange') callback. You can add as many nodechange callbacks as you want.
interface NodeChangeEvent {
nodeChanges: NodeChange[]
type NodeChange: CreateChange | DeleteChange | PropertyChange
type CreateChange: {type: 'CREATE', node: SceneNode | RemovedNode}
type DeleteChange: {type: 'DELETE', node: SceneNode | RemovedNode}
type PropertyChange: {type: 'PROPERTY_CHANGE', properties: NodeChangeProperties[], node: SceneNode | RemovedNode}
pageNode.on('nodechange', (event: NodeChangeEvent) => {})
If you wish to subscribe to only style changes, you can use the new figma.on('stylechange') callback.
interface StyleChangeEvent {
styleChanges: StyleChange[]
type StyleChange: CreateChange | DeleteChange | PropertyChange
type CreateChange: {type: 'STYLE_CREATE', style: PaintStyle | TextStyle | GridStyle | EffectStyle | null}
type DeleteChange: {type: 'STYLE_DELETE', style: PaintStyle | TextStyle | GridStyle | EffectStyle | null}
type PropertyChange: {type: 'STYLE_PROPERTY_CHANGE', properties: StyleChangeProperty[], style: PaintStyle | TextStyle | GridStyle | EffectStyle | null}
figma.on('stylechange', (event: StyleChangeEvent) => {})
// This plugin logs all of the CREATE changes made to the document
// Before
figma.on("documentchange", (e) => {
for (const change of event.documentchanges) {
if (change.type === "CREATE") {
console.log(
`Node ${change.id} created by a ${change.origin.toLowerCase()} user`
// After (a specific page)
const page = await figma.getNodeByIdAsync('2:2')
page.on("nodechange", (e) => {
for (const change of event.nodechanges) {
console.log(
// After (all pages)
for (const change of event.documentChanges) {
console.log(
// After (a style change)
figma.on("stylechange", (e) => {
for(const change of event.stylechanges) {
if(change.type === "STYLE_CHANGE") {
console.log(
`Style ${change.id}`
Accessing all pages
Because loading all pages can be slow in large files, we strongly recommend that you only load pages as needed. Very large files can also run into a memory limit when all pages are loaded.
If you need access to all pages of a document, you can use the new API:
figma.loadAllPagesAsync(): Promise<void>
This method loads all pages in the document and is useful in the following two use cases:
- Traversing the entire document via
DocumentNode.find*methods - Listening for Document Changes
This method is subtly different from loading all pages manually via: await Promise.all(figma.root.children.map(page => page.loadAsync()))
With figma.loadAllPagesAsync, new pages added by other clients will automatically be loaded on the client as well.
