Working in Slides
Figma Slides
Figma Slides is the first presentation tool built for designers and their teammates. No matter your role or level of design experience, Figma Slides makes it easy to create beautiful and effective slide decks. Use Figma Slides to build decks for:
- Design reviews: Share ideas and gather feedback using interactive polls and alignment scales
- Startup pitches: Use clickable prototypes to build excitement with potential investors
- Class projects: Create slide decks together using collaborative tools like audio and cursor chat
- Conference talks: Stay on-message with built-in presenter notes and more!
Getting started with Plugins in Figma Slides
To create a new plugin for Figma Slides, follow the Plugin Quickstart Guide to create a plugin, then come back to this guide.
To update an existing plugin to support Figma Slides, follow the steps below.
Update an existing plugin to support Slides
To enable plugins for Slides, add slides to the editorType field in your plugin's manifest:
"editorType": ["slides"] // or ["figma", "slides", ...]
And, run npm update in the terminal to make sure you have the latest plugin typings for Slides:
npm update
Key differences between plugins in Slides and other plugins
Plugins in Slides have some key differences when compared to other plugins:
New Node Types
Figma Slides introduces four node types: SLIDE, SLIDE_ROW, SLIDE_GRID, and INTERACTIVE_SLIDE_ELEMENT.
SLIDE
SLIDEs are the primary building blocks of Figma Slides, with a fixed size of 1920x1080.
interface SlideNode extends
BaseNodeMixin, SceneNodeMixin, ChildrenMixin,
ContainerMixin, GeometryMixin, CornerMixin,
RectangleCornerMixin, BlendMixin, ConstraintMixin,
LayoutMixin, ExportMixin, FramePrototypingMixin,
ReactionMixin {
readonly type: 'SLIDE'
clone(): SlideNode
To create a slide, use createSlide():
const mySlide = figma.createSlide()
SLIDE_ROW
SLIDE_ROWs are containers for slides and must be children of the SLIDE_GRID.
interface SlideRowNode extends
BaseNodeMixin, SceneNodeMixin, ChildrenMixin {
readonly type: 'SLIDE_ROW'
children: Array<SlideNode>
appendChild(child: SlideNode): void
insertChild(index: number, child: SlideNode): void
To create a Slide Row, use createSlideRow():
const mySlideRow = figma.createSlideRow()
SLIDE_GRID
SLIDE_GRID is the top-level container for slides. It cannot be selected or edited in the UI but can be manipulated through its children (instances of SLIDE_ROW) via the Plugin API.
interface SlideGridNode extends
readonly type: 'SLIDE_GRID'
children: Array<SlideRowNode>
appendChild(child: SlideRowNode): void
insertChild(index: number, child: SlideRowNode): void
These elements include interactive types like POLL, EMBED, FACEPILE, ALIGNMENT, and YOUTUBE. They cannot be created via the Plugin API. However, their positions can be read and manipulated.
interface SlideNode extends BaseNodeMixin, SceneNodeMixin {
readonly type: 'INTERACTIVE_SLIDE_ELEMENT'
readonly interactiveSlideElementType: 'POLL' | 'EMBED' | 'FACEPILE' | 'ALIGNMENT' | 'YOUTUBE'
Additional Features
Grid View and Single Slide View
Figma Slides allows toggling between grid view and single slide view. Access or set the mode using viewport.slidesMode:
const mode: 'grid' | 'single-slide' = figma.viewport.slidesMode
figma.viewport.slidesMode = 'grid' // or 'single-slide'
Focused Slide ID
When in single slide view, access the focused slide using currentPage.focusedSlide:
const focusedSlide: SlideNode | null = figma.currentPage.focusedSlide
figma.currentPage.focusedSlide = slideNode
Reading and Updating the Slide Grid
The slide grid is a 2D representation of slides within a deck. Access the grid using getSlideGrid():
const grid = figma.getSlideGrid()
To reorder slides, use setSlideGrid():
figma.setSlideGrid([...rest, firstRow])
Slide Transitions
Define slide transitions with a specific style, duration, and curve:
style: 'NONE' | 'DISSOLVE' | 'SLIDE_FROM_LEFT', // etc.
duration: number, // 0.01 - 10 seconds
curve: 'EASE_IN' | 'EASE_OUT' | 'LINEAR', // etc.
timing: {
type: 'ON_CLICK' | 'AFTER_DELAY',
delay?: number // 0-30 seconds
Read or update transitions using getSlideTransition() and setSlideTransition():
slideNode.getSlideTransition()
slideNode.setSlideTransition(slideTransition: SlideTransition)
The following transition styles are supported:
'NONE' |
'DISSOLVE' |
'SLIDE_FROM_LEFT' |
'SLIDE_FROM_RIGHT' |
'SLIDE_FROM_TOP' |
'SLIDE_FROM_BOTTOM' |
'PUSH_FROM_LEFT' |
'PUSH_FROM_RIGHT' |
'PUSH_FROM_TOP' |
'PUSH_FROM_BOTTOM' |
'MOVE_FROM_LEFT' |
'MOVE_FROM_RIGHT' |
'MOVE_FROM_TOP' |
'MOVE_FROM_BOTTOM' |
'SLIDE_OUT_TO_LEFT' |
'SLIDE_OUT_TO_RIGHT' |
'SLIDE_OUT_TO_TOP' |
'SLIDE_OUT_TO_BOTTOM' |
'MOVE_OUT_TO_LEFT' |
'MOVE_OUT_TO_RIGHT' |
'MOVE_OUT_TO_TOP' |
'MOVE_OUT_TO_BOTTOM' |
'SMART_ANIMATE'
The following transition curves are supported:
'LINEAR' |
'EASE_IN' |
'EASE_OUT' |
'EASE_IN_AND_OUT' |
'EASE_IN_BACK' |
'EASE_OUT_BACK' |
'EASE_IN_AND_OUT_BACK'
Unsupported and Supported Features
Unsupported in Slides
Slides does not support:
- Components
- Styles
- Variables
- Libraries
Methods unavailable in Slides:
createConnector()createCodeBlock()createSection()createLinkPreviewAsync()setFileThumbnailNodeAsync()
Supported in Slides but not in Design
Slides supports:
createShapeWithText()createTable()createGif()
Additional Notes
When updating existing plugins for Figma Slides:
- Adjust conditions checking for
node.type === 'FRAME'to also check fornode.type === 'SLIDE'. - Use
figma.getSlideGrid().flat().forEach(...)for slide operations.
