Working with Images
Figma plugins are a powerful way to add and manipulate images in Figma files. In the following sections, we show how to add images to your Figma files and modify images within your plugin.
In this guide, you'll learn how to create a plugin that can:
This guide assumes that you’re familiar with the basics of creating Figma plugins. If you’re new to developing plugins, check out the Build your first plugin course — you can copy and paste the code from this guide into the plugin you build.
Add images
In this section, we’ll use a plugin to add images to a Figma file. We can do this a couple of ways:
- Add an image from a known source such as an s3 bucket or web server.
- Add an image from user input.
To use a plugin to add images to a Figma file, an image must be:
PNG,JPG, orGIFformat.- A maximum of 4096 x 4096 px.
- Available to the Figma plugin. For example, a server’s Cross-Origin Resource Sharing (CORS) configuration can sometimes block requests for image files. To avoid network requests altogether, you can include images in your plugin as Base64-encoded data.
Add an image with a known size
The following code sample gets an image from a URL, and inserts a rectangle with the image as a fill.
figma.createNodeFromJSXAsync(
<figma.widget.Image
src="https://picsum.photos/200/300"
width={200}
height={300}
figma.widget.h(
figma.widget.Image,
src: "https://picsum.photos/200/300",
width: 200,
height: 300
The following code sample gets an image from a URL, creates a rectangle, and then renders the image by adding the image as a fill to the rectangle.
// Get an image from a URL.
figma.createImageAsync(
'https://picsum.photos/200'
).then(async (image: Image) => {
// Create a rectangle that's the same dimensions as the image.
const node = figma.createRectangle()
const { width, height } = await image.getSizeAsync()
node.resize(width, height)
// Render the image by filling the rectangle.
node.fills = [
type: 'IMAGE',
imageHash: image.hash,
scaleMode: 'FILL'
Here’s an explanation of what the code is doing:
- To get image data into our plugin, we use the
figma.createImageAsyncmethod. The method returns a Promise that contains an image object. - Because
createImageAsyncreturns a Promise, we use.then()to take action on the image returned by the method. - In Figma, images don’t exist on their own — images are rendered by adding an image as a fill to a node., we create a rectangle node (
figma.createRectangle) that will be used to render the image. - The image object returned by
createImageAsynchas a built-in method namedgetSizeAsync. Rather than hardcoding dimensions for the image into the plugin, we usegetSizeAsyncto get the dimensions of the image we requested in the first step. Then, we set the rectangle node to those dimensions. - To render the image onto the canvas, we add the image to the rectangle node using the
.fillsproperty. Then, we useimageHashto provide the hashed version of the image,image.hash, that was returned bycreateImageAsync.
This code sample hardcodes a URL for createImageAsync. For an example that allows different URLs, check out the next section.
The following code sample expands the previous method. Rather than hardcoding an image URL for createImageAsync, we’re going accept user input from the quick actions menu using plugin parameters. To implement parameters, we need to update our plugin's manifest.json file, as well as the plugin code.
manifest.json
To accept user input, we add the parameters property to our plugin’s manifest.json file:
"name": "Example Name",
"parameters": [
"name": "URL",
"key": "url",
"description": "A URL for a PNG, JPG, or GIF no larger than 4096x4096 px."
The parameters property lets us define a parameter that will store the URL provided by the user.
code.ts
To handle the user’s input, we do a few things to the code for our plugin:
- Add
figma.parameters.on('input')so that the plugin can listen for input from the quick actions menu. - Add
figma.on('run')to pass the URL from the user into our plugin’s existing code. - Wrap the original
figma.createImageAsync(...).then(...)call in a function namedstartPluginWithParameters, which takes the user’s URL from our parameters as input. - In
figma.createImageAsync(...), we replace the hardcoded URL with a reference toparameters.url.
// Listen for input from the quick actions menu.
figma.parameters.on('input', ({query, result}: ParameterInputEvent) => {
result.setSuggestions([query, 'https://picsum.photos/256', 'https://picsum.photos/512'])
// When input is done, run the plugin with the user input as a parameter.
figma.on('run', ({parameters}: RunEvent) => {
startPluginWithParameters(parameters)
// Start the plugin with parameters. Parameters are defined in manifest.json.
async function startPluginWithParameters(parameters: ParameterValues) {
try {
await figma.createImageAsync(
parameters.url
// Your image is added to the canvas
node.fills = [
type: 'IMAGE',
scaleMode: 'FILL'
// If there's an error, notify the user.
} catch (error) {
figma.notify(error)
} finally {
figma.closePlugin()
Now that you can add images to a Figma file using a plugin, you’re ready to start making changes to those images. To learn about manipulating images with a plugin, check out the next section.
Manipulate images
In this section we will look at how to manipulate images within a Figma plugin. We will learn how to retrieve an image from a document, how to decode the image to manipulate its bytes, and how to write a modified image back to the document. As a concrete example, we will show you how to invert the colors of an image.
As you probably know, images in Figma are stored inside the fills of an object. So we first need to retrieve the fills off the current selection.
async function invertImages(node) {
const newFills = []
for (const paint of node.fills) {
if (paint.type === 'IMAGE') {
// Get the (encoded) bytes for this image.
const image = figma.getImageByHash(paint.imageHash)
const bytes = await image.getBytesAsync()
// TODO: Do something with the bytes!
node.fills = newFills
// Assume the current selection has fills.
// In an actual plugin, this won't necessarily be true!
const selected = figma.currentPage.selection[0] as GeometryMixin
invertImages(selected)
Calling getBytesAsync returns the raw bytes of the image, as it is stored on disk. This can be useful if you want to download the image or upload it somewhere else. However, in our case, we want to manipulate the image pixel-by-pixel, as a matrix of RGBA samples. Doing so requires decoding the image.
This could be done by importing some image decoding library. Instead, what we'll do is ask the browser to decode the image for us. We can do this by putting the image in a <canvas> element which will give us access to the getImageData and putImageData functions provided by browsers.
You may recall from the execution model section that you will need to create an <iframe> to access browser APIs. We'll do that later: for now, here is our extended plugin code that sends the original image to the (yet-to-be-implemented) worker, receives a modified image, and replaces the image fill:
const newFills = []
// Create an invisible iframe to act as a "worker" which
// will do the task of decoding and send us a message
// when it's done.
figma.showUI(__html__, { visible: false })
// Send the raw bytes of the file to the worker.
figma.ui.postMessage(bytes)
// Wait for the worker's response.
const newBytes = await new Promise((resolve, reject) => {
figma.ui.onmessage = value => resolve(value)
// Create a new paint for the new image.
const newPaint = JSON.parse(JSON.stringify(paint))
newPaint.imageHash = figma.createImage(newBytes).hash
newFills.push(newPaint)
Now we will implement the worker that will actually decode, modify, and encode the image. It's possible to render UI elements directly in the call to figma.showUI(), but for this example the code needs to be in a separate file referred to by the ui section of the manifest. This worker will need to listen to messages from the plugin code and respond with a message back once it's accomplished its task. We will implement encode and decode later.
<script>
// Create an event handler to receive messages from the main
// thread.
window.onmessage = async (event) => {
// Just get the bytes directly from the pluginMessage since
// that's the only type of message we'll receive in this
// plugin. In more complex plugins, you'll want to check the
// type of the message.
const bytes = event.data.pluginMessage
const canvas = document.createElement('canvas')
const ctx = canvas.getContext('2d')
const imageData = await decode(canvas, ctx, bytes)
const pixels = imageData.data
// Do the actual work of inverting the colors.
for (let i = 0; i < pixels.length; i += 4) {
pixels[i + 0] = 255 - pixels[i + 0]
pixels[i + 1] = 255 - pixels[i + 1]
pixels[i + 2] = 255 - pixels[i + 2]
// Don't invert the alpha channel.
const newBytes = await encode(canvas, ctx, imageData)
window.parent.postMessage({pluginMessage: newBytes}, '*')
</script>
As you can see in the example above, we create a <canvas> object. The handle for the data backing <canvas> is called a context and is obtained with canvas.getContext('2d'). The context allows us to retrieve and write ImageData objects. ImageData objects have a .data field which is an array containing the colors of each sample (or pixel) in the image in sequence, stored as [R, G, B, A, R, G, B, A, ...]. To invert the colors in the image, we take each color channel value and replace it with 255 - value.
To learn more about how RGBA and RGB color values are handled by Figma and plugins, see: RGB/RGBA
Provided below are the implementations of the encode and decode functions.
// Encoding an image is also done by sticking pixels in an
// HTML canvas and by asking the canvas to serialize it into
// an actual PNG file via canvas.toBlob().
async function encode(canvas, ctx, imageData) {
ctx.putImageData(imageData, 0, 0)
return await new Promise((resolve, reject) => {
canvas.toBlob(blob => {
const reader = new FileReader()
reader.onload = () => resolve(new Uint8Array(reader.result))
reader.onerror = () => reject(new Error('Could not read from blob'))
reader.readAsArrayBuffer(blob)
// Decoding an image can be done by sticking it in an HTML
// canvas, as we can read individual pixels off the canvas.
async function decode(canvas, ctx, bytes) {
const url = URL.createObjectURL(new Blob([bytes]))
const image = await new Promise((resolve, reject) => {
const img = new Image()
img.onload = () => resolve(img)
img.onerror = () => reject()
img.src = url
canvas.width = image.width
canvas.height = image.height
ctx.drawImage(image, 0, 0)
const imageData = ctx.getImageData(0, 0, image.width, image.height)
return imageData
The example above won't work for GIFs, which are more like video files than image files. In fact, <canvas> doesn't really support GIFs. You will need to use a third-party Javascript library capable of encoding and decoding GIFs.
