defineProperties
defineProperties allows your component to define customizable properties that control its behavior and appearance. These properties appear in the Figma properties panel and right sidebar of the Figma Sites interface. The editable properties enable users of your component to modify it without editing code.
With defineProperties, you can define one or more properties for a component. Each property has a type. There are four types: string, number, boolean, and reference.
// Example usage of defineProperties with all property types
defineProperties(MyComponent, {
text: { type: 'string', defaultValue: 'Hello' },
count: { type: 'number', defaultValue: 1 },
enabled: { type: 'boolean', defaultValue: true },
icon: { type: 'reference' },
string
string properties let you provide editable fields for entering text. You can set the following options when using the string type:
| Property | Values | Type | Description |
| label | any string | string | Custom label for the property in the UI |
| defaultValue | any string | string | The default value shown in the field |
| control | none (default), select | string | Type of control: text input or dropdown |
| options | list of {value, label} | array of objs | Dropdown options (if control is 'select') |
default string prop
A simple text field with a label and default value.
text: {
type: 'string',
label: 'Display Text',
defaultValue: 'Hello, World!',
placeholder: {
type: 'string',
label: 'Input Placeholder',
defaultValue: 'Enter your name...',
options string prop
Use a dropdown for string properties by setting control: 'select' and providing options.
Options should be an array of objects: { value: string, label: string }.
buttonType: {
type: 'string',
defaultValue: 'normal',
control: 'select',
options: [
{ value: 'normal', label: 'Normal' },
{ value: 'warning', label: 'Warning / Caution' },
{ value: 'secondary', label: 'Secondary' },
number
number properties let users input numeric values. Useful for dimensions, quantities, or any numeric configuration.
| defaultValue | any number | number | The default value shown in the field |
| control | none (default), slider, select | string | Type of control: input, slider, or dropdown |
| min | any number | number | Minimum value (for slider) |
| max | any number | number | Maximum value (for slider) |
| step | any number | number | Step size (for slider) |
| description | any string | string | Optional description for the property |
default number prop
A simple numeric input.
opacity: {
type: 'number',
defaultValue: 1,
label: 'Opacity',
borderWidth: {
type: 'number',
defaultValue: 2,
label: 'Border Width',
description: 'Sets the width of the border in pixels',
slider number prop
Use a slider for number properties by setting control: 'slider' and providing min, max, and step.
opacity: {
type: 'number',
label: 'Opacity',
defaultValue: 0.8,
control: 'slider',
min: 0,
max: 1,
step: 0.1,
padding: {
type: 'number',
label: 'Padding',
defaultValue: 16,
control: 'slider',
min: 0,
max: 32,
step: 4,
options number prop
Use a dropdown for number properties by setting control: 'select' and providing options.
buttonType: {
type: 'number',
defaultValue: 1,
control: 'select',
options: [
{ value: 1, label: 'Regular' },
{ value: 2, label: 'Secondary' },
{ value: 3, label: 'Tertiary' },
boolean
boolean properties let users toggle functionality or visual elements on or off.
| defaultValue | true, false | boolean | The default value |
hasBorder: {
type: 'boolean',
defaultValue: false,
label: 'Enable Border',
isFullWidth: {
type: 'boolean',
defaultValue: true,
label: 'Full Width',
showIcon: {
type: 'boolean',
defaultValue: true,
label: 'Show Icon',
reference
reference properties allow your component to incorporate instances of other components from the current file or attached libraries.
In the Figma Sites interface, in the properties that appear in the code editor or at the top of the right sidebar, you can select a component from your libraries to apply as the value of a reference property.
| defaultValue | React component | component | Default React component to use when no reference is selected |
The name of a key for defineProperties must correspond to a React component in your code. The following examples uses Icon, Avatar, and ActionButton as keys, but these are only examples. The exact names will depend on the code in your code layer or component.
Icon: {
type: 'reference',
label: 'Icon',
defaultValue: ListIcon,
Avatar: {
type: 'reference',
label: 'User Avatar',
defaultValue: DefaultAvatar,
ActionButton: {
type: 'reference',
label: 'Action Button',
The code to implement the previous examples of the reference property might look like this, where ListIcon is a component imported from lucide-react and DefaultAvatar is a React component in your code layer:
import { defineProperties } from "figma:react";
import { List as ListIcon } from "lucide-react";
function DefaultAvatar() {
return (
<div className="w-8 h-8 bg-gray-300 rounded-full">
<svg viewBox="0 0 24 24" fill="currentColor" className="w-full h-full p-1">
<circle cx="12" cy="8" r="3"/>
<path d="M12 14c-4 0-6 2-6 4v2h12v-2c0-2-2-4-6-4z"/>
</svg>
</div>
export default function MyComponent({ Icon, Avatar, ActionButton }) {
return (
<div>
{Icon && <Icon />}
{Avatar && <Avatar />}
{ActionButton && <ActionButton />}
</div>
Icon: {
type: 'reference',
label: 'Icon',
Avatar: {
type: 'reference',
ActionButton: {
type: 'reference',
setter
You can make a property updatable from inside your component by adding a setter to its definition. The setter should be a string matching the name of a function prop that updates the property’s value. When the property is changed in the site, such as when the text of an input changes or a button is clicked, this function will be called with the new value. If the property is bound to a variable, the variable will also be updated.
This enables two-way data flow between your component and the Figma UI, allowing code layers and component instances to share and update data.
The setter is typically used with React state setters (in the examples, setText, setSize, setMode). The function receives the new value as its argument.
Text setter example
import { useState } from "react";
export default function ExampleTextLayer({ text, setText }) {
const handleTextChange = (event) => {
setText(event.target.value);
return (
<div>
<div>
<label htmlFor="text-input" className="block">
Text:
</label>
<input
id="text-input"
type="text"
value={text}
onChange={handleTextChange}
className="p-1 border rounded"
</div>
</div>
defineProperties(ExampleTextLayer, {
text: {
type: "string",
defaultValue: "Hello, world!",
setter: "setText",
Number setter example
export default function ExampleNumberLayer({
size,
setSize,
const handleSizeChange = (event) => {
setSize(parseFloat(event.target.value));
return (
<div>
<div>
<label htmlFor="size-input" className="block">
Size:
</label>
<input
id="size-input"
type="number"
value={size}
onChange={handleSizeChange}
</div>
</div>
defineProperties(ExampleNumberLayer, {
type: "number",
defaultValue: 10,
setter: "setSize",
Boolean setter example
export default function ExampleBooleanLayer({ mode, setMode }) {
const toggleValue = () => setMode(!mode); // true = dark, false = light
return (
<div className="flex flex-col items-center space-y-4">
<button
type="button"
onClick={toggleValue}
className="w-16 h-16 bg-transparent border-2 border-black text-black rounded-full flex items-center justify-center text-sm text-center hover:shadow-inner transition-shadow"
{mode ? 'Dark' : 'Light'}
</button>
</div>
defineProperties(ExampleBooleanLayer, {
mode: {
type: "boolean",
setter: "setMode",
