Working in Buzz
Buzz
Figma Buzz enables brand designers to create and share on-brand assets, so teammates can grab what they need, when they need it. Buzz's simple design editor lets marketers or other teams create the assets they need quickly. Use Figma Buzz to make assets such as social media posts, digital ads, event materials, and more.
- Publish templates: Build assets using the creation tools in Figma Buzz or copy and paste designs from Figma Design, make necessary tweaks in Design mode, and publish in Figma Buzz for your peers to easily access and use.
- Focused editing: Teams can edit select sections within published templates, ensuring they are always staying on brand.
- Freeform editing: Remove template guidelines from a team template, start from scratch, or use a Figma-created template to edit freely and create exactly what you need. Riff and refine with design tools in a simplified editor.
- Creation at scale: Quickly create and edit thousands of assets at once. See them all in one view, regardless of size.
Getting started with Plugins in Figma Buzz
To create a new plugin for Figma Buzz, follow the Plugin Quickstart Guide to create a plugin, then come back to this guide.
To update an existing plugin to support Figma Buzz, follow the steps below.
Update an existing plugin to support Buzz
To enable plugins for Buzz, add buzz to the editorType field in your plugin's manifest:
"editorType": ["buzz"] // or ["figma", "buzz", ...]
Then, run npm update in the terminal to make sure you have the latest plugin typings for Buzz:
npm update
Key differences between plugins in Buzz and other plugins
Plugins in Buzz have some key differences when compared to other plugins:
Plugin entry point
To ensure better discoverability for plugins, all Buzz plugins will show up in the left side panel by default and take up the entire height. Users will also be able to pop the plugin out into a modal. Because this left panel is resizable, we strongly recommend that you design your plugin iframes using the following guidelines:
- Make sure the content inside of your plugin iframe can handle responsive resizing
- Design your content vertically and to handle scrolling overflow
Views
Buzz supports two modes—grid view and asset view.
- Grid view lets you interact with all assets in a structured 2D layout
- Asset view allows focus on one asset in isolation
Tip: While you can add nodes anywhere on the canvas, you typically want to add the node to the grid so that users can see the node in asset view. To do this, you should:
- Use
figma.buzz.createFrame()as opposed tofigma.currentPage.appendChild(). - Use
figma.moveNodesToCoord()to insert a node into the grid (i.e. you've duplicated a frame with.cloneand want to insert into the canvas grid).
Asset Types
Buzz introduces predefined asset types for common marketing formats like Instagram Stories or LinkedIn Ads. See the BuzzAssetType documentation for a complete enumeration of the types.
Canvas Grid Management
Buzz uses a canvas grid system to organize media assets. You can programmatically manage this grid using:
figma.getCanvasGrid()- Get the current canvas grid as a 2D arrayfigma.setCanvasGrid(grid)- Reorganize the canvas grid layoutfigma.createCanvasRow(index?)- Create a new row in the canvas gridfigma.moveNodesToCoord(nodes, row?, column?)- Move nodes to specific grid positions
Canvas View Management
Access or set the current view mode using figma.viewport.canvasView:
// Get current view
const currentView = figma.viewport.canvasView // 'grid' | 'single-asset'
// Set the view mode
figma.viewport.canvasView = 'single-asset'
Focused Node Access
When in asset view, access the currently focused node:
// Get the focused node
const focusedNode = figma.currentPage.focusedNode
// Set the focused node
figma.currentPage.focusedNode = someNode
Working with Buzz-Specific APIs
The figma.buzz API provides specialized methods for media content:
// Create frames optimized for the canvas grid
const frame = figma.buzz.createFrame(0, 0) // row 0, column 0
// Manage asset types
figma.buzz.setBuzzAssetTypeForNode(frame, 'INSTAGRAM_STORY')
const assetType = figma.buzz.getBuzzAssetTypeForNode(frame)
// Extract and update content
const textFields = figma.buzz.getTextContent(frame)
const mediaFields = figma.buzz.getMediaContent(frame)
// Smart resizing for different platforms
figma.buzz.smartResize(frame, 1080, 1080)
Event Handling
Listen for canvas view changes to adapt your plugin's behavior:
figma.on('canvasviewchange', (event) => {
if (event.view === 'SINGLE_ASSET') {
// User focused on single asset
console.log('Asset view')
} else {
// User viewing grid
console.log('Grid view')
Best Practices
- Any nodes that are added to the canvas should be added specifically to the grid. For example, if you clone a node, make sure you move it to the canvas:
// Move cloned node to grid
const cloned = node.clone();
if (figma.editorType === 'buzz') {
figma.moveNodesToCoord([cloned.id], row, col); // NEW
// If creating a frame, you can use the createFrame() function
const frame = figma.buzz.createFrame(row, col);
- When inserting images into a Buzz asset, avoid directly setting image fills on the top-level frame. Instead, create a rectangle node with the image fill and insert it as a child of the top-level frame. This approach ensures that the image appears as a separate object within the frame rather than replacing the frame's background fill, which is consistent with how images are inserted from the Media side panel in the Buzz Editor.
// Get the selected Buzz asset (top-level frame)
const buzzAsset = figma.currentPage.selection[0];
// Create a rectangle to hold the image
const rectangleNode = figma.createRectangle();
// Load and apply the image fill
const image = figma.createImage(imageBytes); // your image data as Uint8Array
rectangleNode.fills = [{
type: 'IMAGE',
imageHash: image.hash,
scaleMode: 'FILL'
// Size the rectangle appropriately
rectangleNode.resize(400, 300);
// Insert the rectangle as a child of the Buzz asset
buzzAsset.appendChild(rectangleNode);
// Alternatively, you can use the Buzz Media Content API
// if working with template-based assets that have predefined media fields
// and you'd like to replace the image fill of one of those media fields
const mediaContent = figma.buzz.getMediaContent(buzzAsset);
if (mediaContent.length > 0) {
await mediaContent[0].setMediaAsync(image.hash, 'IMAGE');
Unsupported and Supported Features
Unsupported in Buzz
Buzz does not support these node types:
CANVASSTICKYCONNECTORCODE_BLOCKTABLEMEDIAWEBPAGESLIDEINTERACTIVE_SLIDE_ELEMENT
Methods unavailable in Buzz:
createPage()createConnector()createCodeBlock()createTable()createSticky()createSlide()createSlideRow()createPageDivider()createLinkPreviewAsync()setFileThumbnailNodeAsync()
Additional Notes
When updating existing plugins for Figma Buzz:
- Use
figma.buzz.createFrame()instead offigma.createFrame()for grid-aware positioning - Check for
figma.editorType === 'buzz'to enable Buzz-specific functionality - Consider responsive design for the resizable left panel interface
- Use asset types to ensure proper platform formatting
