Property types
In the previous section, we gave you a brief description of the comment types. The client_meta property of comments takes a custom Figma type, which is described below.
Region and FrameOffsetRegion represent comments that span a region. By default, the comment_pin_corner is in the bottom right. As an illustration, the following diagram shows how node_offset, region_height, and region_width interact with each other.
^node_offset origin |
| | region_width | |
| |region_height | |
| +--------------------+ <- node_offset |
| Type | Properties |
FrameOffsetPosition of a comment relative to the frame to which it is attached. |
RegionPosition of a region comment on the canvas. |
FrameOffsetRegionPosition of a region comment relative to the frame to which it is attached. |
