Endpoints
Components and styles endpoints allow several ways to get information about published components and styles in a team library. You can get a list of components or styles using a team_id, or a specific component or style using a key.
GET team components
Get a paginated list of published components within a team library.
info
HTTP Endpoint
GET /v1/teams/:team_id/components
Return value
"status": Number,
"error": Boolean,
"meta": {
"components": [
"key": String,
"file_key": String,
"node_id": String,
"thumbnail_url": String,
"name": String,
"description": String,
"updated_at": String,
"created_at": String,
"user": User,
"containing_frame": FrameInfo,
"cursor": {
"before": Number,
"after": Number,
Path parametersDescription
team_id
String
ID of the team to list components from.
Query parametersDescription
page_size
Numberdefault: 30
Number of items in a paged list of results. Maximum of 1000.
after
Number
Cursor indicating which id after which to start retrieving components for. Exclusive with before. The cursor value is an internally tracked integer that doesn't correspond to any Ids.
before
Number
Cursor indicating which id before which to start retrieving components for. Exclusive with after. The cursor value is an internally tracked integer that doesn't correspond to any Ids.
Error codesDescription
400Error with the request. The message param on the response will describe the error.
403Insufficient permission on the team. This could also indicate the developer / OAuth token is invalid or expired.
404Requested resource was not found.
GET file components
Get a list of published components within a file library.
info
This is a Tier 3 endpoint and requires the library_content:read scope.
HTTP Endpoint
GET /v1/files/:file_key/components
Return value
"status": Number,
"error": Boolean,
"meta": {
"components": [
"key": String,
"file_key": String,
"node_id": String,
"name": String,
"user": User,
file_key
String
File to list components from. This must be a main file key, not a branch key, as it is not possible to publish from branches.
GET component
Get metadata on a component by key.
info
This is a Tier 3 endpoint and requires the library_assets:read scope.
HTTP Endpoint
GET /v1/components/:key
Return value
"status": Number,
"error": Boolean,
"meta": {
"key": String,
"file_key": String,
"node_id": String,
"name": String,
"user": User,
key
String
The unique identifier of the component.
GET team component sets
Get a paginated list of published component sets within a team library.
info
HTTP Endpoint
GET /v1/teams/:team_id/component_sets
Return value
"status": Number,
"error": Boolean,
"meta": {
"component_sets": [
"key": String,
"file_key": String,
"node_id": String,
"name": String,
"user": User,
"cursor": {
"before": Number,
"after": Number,
team_id
String
ID of the team to list component sets from.
page_size
Numberdefault: 30
after
Number
before
Number
GET file component sets
Get a list of published component sets within a file library.
info
HTTP Endpoint
GET /v1/files/:file_key/component_sets
Return value
"status": Number,
"error": Boolean,
"meta": {
"component_sets": [
"key": String,
"file_key": String,
"node_id": String,
"name": String,
"user": User,
file_key
String
File to list component sets from. This must be a main file key, not a branch key, as it is not possible to publish from branches.
GET component set
Get metadata on a component set by key.
info
HTTP Endpoint
GET /v1/component_sets/:key
Return value
"status": Number,
"error": Boolean,
"meta": {
"key": String,
"file_key": String,
"node_id": String,
"name": String,
"user": User,
key
String
The unique identifier of the component set.
GET team styles
Get a paginated list of published styles within a team library.
info
HTTP Endpoint
GET /v1/teams/:team_id/styles
Return value
"status": Number,
"error": Boolean,
"meta": {
"styles": [
"key": String,
"file_key": String,
"node_id": String,
"style_type": StyleType,
"name": String,
"sort_position": String,
"user": User,
"cursor": {
"before": Number,
"after": Number,
team_id
String
ID of the team to list styles from.
page_size
Numberdefault: 30
after
Number
Cursor indicating which id after which to start retrieving styles for. Exclusive with before. The cursor value is an internally tracked integer that doesn't correspond to any Ids.
before
Number
Cursor indicating which id before which to start retrieving styles for. Exclusive with after. The cursor value is an internally tracked integer that doesn't correspond to any Ids.
GET file styles
Get a list of published styles within a file library.
info
HTTP Endpoint
GET /v1/files/:file_key/styles
Return value
"status": Number,
"error": Boolean,
"meta": {
"styles": [
"key": String,
"file_key": String,
"node_id": String,
"name": String,
"user": User,
file_key
String
File to list styles from. This must be a main file key, not a branch key, as it is not possible to publish from branches.
GET style
Get metadata on a style by key.
info
HTTP Endpoint
GET /v1/styles/:key
Return value
"status": Number,
"error": Boolean,
"meta": {
"key": String,
"file_key": String,
"node_id": String,
"name": String,
"user": User,
key
String
The unique identifier of the style.
