Endpoints
Dev Resources endpoints allow you to create, read, update, and delete dev resources in Figma files.
GET dev resources
Get dev resources in a file.
This is a Tier 2 endpoint and requires the file_dev_resources:read scope.
HTTP endpoint
GET /v1/files/:file_key/dev_resources
Return value
"dev_resources": DevResource[]
| Path parameters | Description |
| file_key |
| Query parameters | Description |
| node_ids |
| Error codes | Description |
| 400 | Invalid parameter. The message parameter on the response will describe the error. |
| 401 | Issue with authentication. The message parameter on the response will describe the error. |
POST dev resources
Bulk create dev resources across multiple files.
Dev resources that are successfully created will show up in the links_created array in the response.
If there are any dev resources that cannot be created, you may still get a 200 response. These resources will show up in the errors array. Some reasons a dev resource cannot be created include:
- Resource points to a
file_keythat cannot be found. - The node already has the maximum of 10 dev resources.
- Another dev resource for the node has the same url.
This is a Tier 2 endpoint and requires the file_dev_resources:write scope.
HTTP endpoint
POST /v1/dev_resources
Return value
"links_created": DevResource[]
"errors": [
"file_key": String | null,
"node_id": String | null,
"error": String,
| Body parameters | Description |
| dev_resources |
PUT dev resources
Bulk update dev resources across multiple files.
Ids for dev resources that are successfully updated will show up in the links_updated array in the response.
If there are any dev resources that cannot be updated, you may still get a 200 response. These resources will show up in the errors array.
HTTP endpoint
PUT /v1/dev_resources
Return value
"links_updated": String[]
"errors": [
"id": String,
"error": String,
| dev_resources |
DELETE dev resources
Delete a dev resources from a file.
HTTP endpoint
DELETE /v1/files/:file_key/dev_resources/:dev_resource_id
Return value
Nothing is returned from this endpoint
| file_key |
| dev_resource_id |
| 404 | The specified dev resource / file was not found |
