Endpoints
POST developer logs
This API is available to organization administrators on Enterprise plans with the Governance+ add-on.
The POST /v1/developer_logs endpoint lets you search for API access records across your organization. You can filter by token, user, IP address, token type, event source, and date range.
info
This is a Tier 3 endpoint and requires the org:developer_log_read scope. This endpoint can only be used with a plan access token.
HTTP Endpoint
Return value
"status": Number,
"error": Boolean,
"meta": {
"items": [
"uuid": String,
"timestamp": String,
"action": {
"event_name": String,
"event_source": String
"actor": {
"user_id": String,
"user_name": String,
"token_name": String,
"token_type": String,
"user_email": String
"resource": {
"id_or_key": String,
"name": String,
"type": String,
"org_id": String
"context": {
"ip_address": String,
"city": String,
"country_region": String,
"country": String
"cursor": String,
"has_more": Boolean
Body parametersDescription
token
String
An access token secret (e.g., figu_12345). The token is hashed to find matching API access records that were authenticated with it. This is useful for investigating a leaked token.
token_name
String
A name or prefix of a personal access token, plan access token, or OAuth app. Accepts a comma-separated list of values that are treated as an OR condition.
user_email
String
A name or prefix of a user's email address. Searches for API calls made with a personal access token or OAuth connection from the given user. This will not return results for plan access tokens, since those are not tied to an individual user. Accepts a comma-separated list of values that are treated as an OR condition.
ip_address
String
An IP address or prefix. Searches for API calls made from the given IP address. Accepts a comma-separated list of values that are treated as an OR condition.
token_type
String
The type of token used to authenticate the API call, as a string enum.
  • PLAN_ACCESS_TOKEN
  • PERSONAL_ACCESS_TOKEN
  • OAUTH_TOKEN
event_source
String
The source of the API call, as a string enum.
  • REST_API
  • MCP_SERVER
date_range
String
The time range to search within, as a string enum.
  • LAST_24H
  • LAST_7D
  • LAST_30D
limit
Numberdefault: 25
Limit the number of records to return. Maximum value is 100.
cursor
String
Cursor for pagination. Used to retrieve the next page of data. Obtained from the cursor field in the response of the previous call.
Error codesDescription
400Invalid parameter. The message parameter on the response will describe the error.
401Issue with authentication. The message parameter on the response will describe the error.
403API is not available. Possible error messages are Limited by Figma plan, Incorrect account type, or Invalid scope. This could also indicate the developer / OAuth token is invalid or expired.
Example
The following is an example response from the POST developer logs endpoint. The items array contains log entries for both REST API and MCP server events.
"error": false,
"status": 200,
"meta": {
"items": [
"uuid": "5f429b01-b1e0-4f82-8767-a41013ec2da2",
"timestamp": "2026-04-14T21:35:11.086Z",
"action": {
"event_name": "/v1/activity_logs",
"event_source": "rest_api"
"actor": {
"user_id": "1234567890",
"user_name": "Sally Fields",
"token_name": "Audit Log Ingestion",
"token_type": "oauth_token",
"user_email": "sfields@figma.com"
"resource": {
"org_id": "1234567890"
"context": {
"ip_address": "1.2.3.4",
"city": "Boardman",
"country_region": "OR",
"country": "US"
"uuid": "cfb9afbe-be2f-43fc-8e66-deb803b17452",
"timestamp": "2026-04-14T21:40:29.881Z",
"action": {
"event_name": "get_figjam",
"event_source": "mcp_server"
"actor": {
"user_name": "John Hancock",
"token_name": "Claude Code MCP",
"user_email": "jhancock@figma.com"
"resource": {
"id_or_key": "OWkR3ICVMqixoNdC9dr1jK",
"name": "Offsite Agenda",
"type": "file",
"context": {
"city": "Alameda",
"country_region": "CA",
"country": "US"
"cursor": "[1776202465493,'7b59a325-c4c8-4faa-9944-f8e58746c235']",
"has_more": true
