Endpoints
There are six methods provided by the Library Analytics REST API. Components, styles, and variables each have an actions endpoint and a usages endpoint.
GET component actions: Get time series data about what actions your users have performed with your library's components on a week-by-week basis.
GET component usages: Get summary information about how many instances of a library's components exist across all files.
GET styles actions: Get time series data about what actions your users have performed with your library's styles on a week-by-week basis.
GET styles usages: Get summary information about how many instances of a library's styles exist across all files.
GET variables actions: Get time series data about what actions your users have performed with your library's variables on a week-by-week basis.
GET variables usages: Get summary information about how many instances of a library's variables exist across all files.
The /v1/analytics/libraries/:library_file_key/component/actions endpoint provides historical time series data regarding how a design system library is used. The data is returned in descending order, from most recent to least recent. Action data can be returned broken down in different ways using the required group_by query parameter. Data is available for up to one year.
Types of events
We track two types of events:
insertions: Tracks how many times a component in the library was inserted into a document. This can happen in many ways, including: duplicating an existing instance, copy pasting the instance from another document, or inserting the component from the asset panel.detachments: Tracks how many times a component in the library was detached.
Data sparseness
Only weeks containing data are returned. Teams and components only appear when there are associated actions.
This is a Tier 3 endpoint and requires the library_analytics:read scope.
HTTP endpoint
GET /v1/analytics/libraries/:library_file_key/component/actions
Return value
"cursor": String,
"next_page": Boolean,
"rows": [
"component_key": String,
"week": String,
"detachments": Number,
"insertions": Number,
"component_name": String,
"component_set_key": String,
"component_set_name": String
"cursor": String,
"rows": [
"week": String,
"team_name": String,
"workspace_name": String
| Path parameters | Description |
| library_file_key |
| Query parameters | Description |
| group_by |
| start_date |
| end_date |
| cursor |
| Error codes | Description |
| 400 | Invalid parameter. The message parameter on the response will describe the error. |
| 401 | Issue with authentication. The message parameter on the response will describe the error. |
| 403 | API is not available. Possible error messages are Limited by Figma plan, Incorrect account type, or Invalid scope. This could also indicate the developer / OAuth token is invalid or expired. |
The /v1/analytics/libraries/:library_file_key/component/usages endpoint provides data on how components are used across different files and teams. This data can be broken down by component or file.
Components and files
The endpoint can group usage by:
component: Returns a list of all the components with usage in the library (unused components are excluded). The response includes the name of the component, the number of files and teams using the component, and the total number of existing instances of the component.file: Returns a list of all the files that use the library. The response includes the team name, the file name, and the total number of times that resources from the library are used. Files that you don't have access to are returned asFile not visible. A total count of instances used in those files is also included in the response.
Data sparseness
Rows only include teams or components with data.
HTTP endpoint
GET /v1/analytics/libraries/:library_file_key/component/usages
Return value
"cursor": String,
"rows": [
"usages": Number
"teams_using": Number,
"files_using": Number,
"cursor": String,
"rows": [
"usages": Number,
"workspace_name": String,
"file_name": String
| library_file_key |
| group_by |
| cursor |
GET styles actions
The /v1/analytics/libraries/:library_file_key/style/actions endpoint provides historical time series data regarding how design system styles were used. The data is returned in descending order, from most recent to least recent. Actions data can be returned organized in different ways using the required group_by query parameter.
Data sparseness
Only weeks containing data are returned. Teams and styles only appear when there are associated actions.
HTTP endpoint
GET /v1/analytics/libraries/:library_file_key/style/actions
Return value
"cursor": String,
"rows": [
"style_key": String,
"week": String,
"style_name": String,
"style_type": String
"cursor": String,
"rows": [
"week": String,
| library_file_key |
| group_by |
| start_date |
| end_date |
| cursor |
GET styles usages
The /v1/analytics/libraries/:library_file_key/style/usages endpoint provides data on how styles are used across different files and teams. This data can be broken down by style or file.
Data sparseness
Rows only include teams or styles with data.
HTTP endpoint
GET /v1/analytics/libraries/:library_file_key/style/usages
Return value
"cursor": String,
"rows": [
"usages": Number,
"cursor": String,
"rows": [
"usages": Number,
"file_name": String,
| library_file_key |
| group_by |
| cursor |
The /v1/analytics/libraries/:library_file_key/variable/actions endpoint provides historical time series data regarding how variables within a design system were used. The data is returned in descending order, from most recent to least recent. The data can be grouped by variable or by team.
Data sparseness
Only weeks containing data are returned. Teams and variables only appear when there are associated actions.
HTTP endpoint
GET /v1/analytics/libraries/:library_file_key/variable/actions
Return value
"cursor": String,
"rows": [
"variable_key": String,
"week": String,
"variable_name": String,
"variable_type": String,
"collection_key": String,
"collection_name": String
"cursor": String,
"rows": [
"week": String,
| library_file_key |
| group_by |
| start_date |
| end_date |
| cursor |
The /v1/analytics/libraries/:library_file_key/variable/usages endpoint provides data on how variables are used across different files and teams. This data can be grouped by variable or file.
Data sparseness
Rows only include teams or variables with data.
HTTP endpoint
GET /v1/analytics/libraries/:library_file_key/variable/usages
Return value
"cursor": String,
"rows": [
"usages": Number,
"cursor": String,
"rows": [
"usages": Number,
| library_file_key |
| group_by |
| cursor |
