Endpoints
See information about your projects and files within a project.
Limited Access
The projects endpoints can only be used with private OAuth apps.
GET team projects
You can use this endpoint to get a list of all the projects within the specified team. It returns only projects visible to the authenticated user or owner of the developer token.
It is not possible to programmatically obtain team IDs. To obtain a team ID, navigate to the team page in the Figma file browser. The team ID is present in the URL after the word team and before your team name.
This is a Tier 2 endpoint and requires the projects:read scope.
HTTP Endpoint
GET /v1/teams/:team_id/projects
| Path parameters | Description |
| team_id |
| Error codes | Description |
| 400 | Error with the request. The "message" param on the response will describe the error. |
| 403 | The developer / OAuth token is invalid or expired |
GET project files
List the files in a given project.
HTTP Endpoint
GET /v1/projects/:project_id/files
| project_id | |
| branch_data |
| 400 | Error with the request. The message param on the response will describe the error. |
