Examples
This section provides examples of how the SCIM API endpoints can be used.
PATCH groups: Add User to Group
Adds a user to an existing group in Figma using the SCIM API. This example demonstrates how to use the PATCH groups endpoint to update group membership. You must know the Figma group ID and the user ID of the member you want to add.
HTTP endpoint
PATCH :baseURL/Groups/:figmaGroupId
:figmaGroupId is a required path parameter, the Figma group ID of the target group.
For example, a group ID returned from GET :baseURL/Groups: "id": "1b5f9234-df40-4664-9767-334fdd7d51f6"
Headers
Authorization = "Bearer [FIGMA API TOKEN]"
Content-Type = application/json
Example request body
"schemas": [
"urn:ietf:params:scim:api:messages:2.0:PatchOp"
"Operations": [
"op": "add",
"path": "members",
"value": [
"value": "1360815874257948001",
"display": "newscimuser@example.com"
Example response body
"schemas": [
"urn:ietf:params:scim:schemas:core:2.0:Group"
"id": "1b5f9234-df40-4664-9767-334fdd7d51f6",
"members": [
"value": "1427545874257949557",
"display": "existingscimuser@example.com"
"external_id": "123456789",
"displayName": "Existing Group",
"meta": {
"resourceType": "Group",
"created": "2024-10-17T02:22:22Z",
"lastModified": "2024-10-17T04:03:06Z",
"version": "W/\"1729137786\"",
"location": "https://www.figma.com/scim/v2/1401286822445493852/Groups/1b5f9234-df40-4664-9767-334fdd7d51f6"
In this example, after adding the user to the group, a subsequent request to GET the group will show the updated membership list.
PUT users: Soft Delete User
Deletes a user in Figma but maintains SCIM provisioning of that user. This is an example of a specific usage of the PUT users endpoint. You can update the active attribute to false. This will delete the user from Figma, but maintain a record in the SCIM provisioning log of the user. This means the user will be listed if you were to leverage the GET users endpoint in bulk or by email filter.
HTTP endpoint
PUT :baseURL/Users/:figmaUserId
:figmaUserId is a required path parameter, the Figma user ID of the operation's target user.
For example, a user ID returned from GET :baseURL/USERS: "id": "977321366678728562"
Headers
"schemas": ["urn:ietf:params:scim:schemas:core:2.0:User", "urn:ietf:params:scim:schemas:extension:enterprise:2.0:User"],
"userName": "scimuser@example.com",
"name": {
"givenName": "Scim",
"familyName": "User"
"emails": {
"primary": "true",
"value": "scimuser@example.com",
"type": "work"
"title": "Developer",
"displayName": "Scim User",
"active": false,
"externalId": "123456789"
"schemas": [
"name": {
"emails": {
"primary": "true",
"type": "work"
"active": false,
"id": "974330387624283297",
"meta": {
"resourceType": "User",
"created": "2021-05-12T15:21:06Z",
"lastModified": "2021-05-13T00:11:04Z",
"version": "W/\"1620864664\"",
"location": "https://www.figma.com/scim/v2/964615200748176016/Users/974330387624283297"
In this example, when running a subsequent request to GET Users, the totalResults are 5, and the user is still listed.
