Supported Schemas
The SCIM API supports the following schemas.
["urn:ietf:params:scim:schemas:core:2.0:User"]
| Parameter name | Example | Description |
| roles | | Array. Enterprise plan only. Each item in the array is an object with two properties: "type": "seatType" and "value":, which must be one of Full, Dev, Collab, or View. |
| givenName | John | |
| familyName | Doe | |
| displayName | John Doe | This value is limited to 100 characters or less. |
| title | Design Manager | |
| userName | johndoe@example.com | String. The user's email. Changing this attribute will change the user account's email in Figma. This value is limited to 100 characters or less. |
| active | true | Boolean. Use this parameter to deactivate or reactivate users in Figma. Deactivated users are removed from the organization. |
| externalId | aaaabbbbbbccccc | String. The IdP's external ID for the user. Figma stores but does not use this parameter. This value is limited to 255 characters or less. |
["urn:ietf:params:scim:schemas:extension:enterprise:2.0:User"]
| employeeNumber | 70198422 |
| costCenter | 093923 |
| organization | Product |
| division | Mobile |
| department | Designers |
| managerValue | examplemanager@example.com |
| managerDisplayName | John Doe |
["urn:ietf:params:scim:schemas:core:2.0:Group"]
| displayName | example_group_name | String. Sets the name of the SCIM group. This value is limited to 255 characters or less. |
| members | | Array. A list of members for the SCIM group. |
| externalId | 123456789 | String. An ID that uniquely identifies the group in the IdP. This value is limited to 255 characters or less. |
Custom Parameters
The custom parameter provided by this schema is used to designate organization administrators.
info
Note: Previously, product seats were managed using custom parameters. Seats are now managed using the roles parameter, a part of the Core user schema.
["urn:ietf:params:scim:schemas:extension:figma:enterprise:2.0:User"]
| figmaAdmin | true | Boolean. Enterprise plan only. If true sets the user as a Figma organization administrator. |
