PINGDebug event triggered whenever a webhook is created. Use this to verify that your endpoint was setup correctly. | event_typeStringThe type of the event, as a string enum. passcodeString- The passcode specified when the webhook was created, should match what was initially provided.
timestampString- UTC ISO 8601 timestamp of when the event was triggered.
webhook_idNumber- The id of the webhook that caused the callback.
Example: { "event_type": "PING", "passcode": "secretpasscode", "timestamp": "2020-02-23T20:27:16Z", "webhook_id": "22" }
FILE_UPDATETriggers within 30 minutes of editing inactivity in a file. | event_typeStringThe type of the event, as a string enum. file_keyString- The key of the file that was updated.
file_nameString- The name of the file that was updated.
Example: { "event_type": "FILE_UPDATE", "file_key": "CL06nJNn5eZLQKDoARMND5", "file_name": "Developer page mockup demo", "passcode": "secretpasscode", "timestamp": "2020-02-23T20:27:16Z", "webhook_id": "22" }
FILE_DELETETriggers whenever a file has been deleted. If you subscribe to FILE_UPDATE, you automatically get these notifications. Note that this does not trigger on all files within a folder, if the folder is deleted. | event_typeStringThe type of the event, as a string enum. file_keyString- The key of the file that was deleted.
file_nameString- The name of the file that was deleted.
triggered_byUser- The user that deleted the file and triggered this event.
Example: { "event_type": "FILE_DELETE", "file_key": "CL06nJNn5eZLQKDoARMND5", "file_name": "Developer page mockup demo", "passcode": "secretpasscode", "timestamp": "2020-02-23T20:27:16Z", "webhook_id": "22" }
FILE_VERSION_UPDATETriggers whenever a user creates a named version in the version history of a file. This is useful for workflow integrations. For example, suppose you have a Figma document with icon assets. When the design for an asset is updated and ready to publish, you can have a member of the team tag that version in the version history and then use this webhook event to generate and deploy your new asset version. | event_typeStringThe type of the event, as a string enum. file_keyString- The key of the file that was updated.
created_atString- UTC ISO 8601 timestamp of when the version was created.
version_idString- ID of the published version.
labelString- Label of the version in the version history.
descriptionString- Description of the version in the version history.
Example: { "created_at": "2020-02-23T20:27:16Z", "event_type": "FILE_VERSION_UPDATE", "file_key": "CL06nJNn5eZLQKDoARMND5", "file_name": "Developer page mockup demo", "version_id": "443", "label": "Added new documentation!", "description": "Wrote new documentation for webhooks v2", "passcode": "secretpasscode", "timestamp": "2020-02-23T20:27:16Z", "triggered_by": { "id": "813845097374535682", "handle": "Dylan Field" }, "webhook_id": "22" }
LIBRARY_PUBLISHTriggers whenever a library file is published. This is useful for workflow integrations. This webhook could integrate with Slack, Asana or Jira, notifying designers to modify their assets when new components are published. Note: depending on the type and number of assets that were published, a single publication may be delivered via multiple, separate LIBRARY_PUBLISH webhook events. There will be a separate LIBRARY_PUBLISH event for each type of published library asset (components, styles, and/or variables). Additionally, publications with a large number of assets (typically hundreds) will also be split into multiple separate events. | event_typeStringThe type of the event, as a string enum. file_keyString- The key of the file that was published.
file_nameString- The name of the file that was published.
descriptionString- Description of the library publish.
created_componentsLibraryItemData[]- Components that were created by the library publish.
created_stylesLibraryItemData[]- Styles that were created by the library publish.
created_variablesLibraryItemData[]- Variables that were created by the library publish.
modified_componentsLibraryItemData[]- Components that were modified by the library publish.
modified_stylesLibraryItemData[]- Styles that were modified by the library publish.
modified_variablesLibraryItemData[]- Variables that were modified by the library publish.
deleted_componentsLibraryItemData[]- Components that were deleted by the library publish.
deleted_stylesLibraryItemData[]- Styles that were deleted by the library publish.
deleted_variablesLibraryItemData[]- Variables that were deleted by the library publish.
triggered_byUser- The user that published the file and triggered this event.
Example: { "event_type": "LIBRARY_PUBLISH", "file_key": "zH44k2FUM629Fa4EMShiHL", "file_name": "Mockup library", "description": "Adjusted colors to match guidelines", "created_components": [ { "key": "ed26a50a541c7e6828420a68707eb49812bda2d3", "name": "Simple button" } ], "created_styles": [ { "key": "a68707eb49ed26828420812bda2d36a50a541c7e", "name": "Coral green" } ], "modified_components": [ { "key": "eacab7bc887f50d99d73ef0eaf6716d5dae0855f", "name": "Date picker" } ], "modified_styles": [ { "key": "50d99d73ef0ab7bc887f716d5dae0855feaf6eac", "name": "Background fill" } ], "deleted_components": [ { "key": "0a575f0b60f7238d9f7da3e8d57b99ab4451f28f", "name": "Slider" } ], "deleted_styles": [ { "key": "0b60f0a577b99ab4451f25f7238d9f7da3e8d58d", "name": "Header text" } ], "passcode": "secretpassword", "timestamp": "2020-02-23T20:27:16Z", "triggered_by": { "id": "813845097374535682", "handle": "Dylan Field" }, "webhook_id": "22" }
Triggers whenever a user comments on a file. This webhook could integrate with Asana or Jira and automatically create tasks whenever a user comments. It could also integrate with Slack and notify mentioned users. The contents of a comment is returned in an array of CommentFragment. A CommentFragment either contains a text or mention field. A text field contains raw comment text with formatting derivatives, newlines will be encoded as \n, etc. Text fields can also contain emojis, which are always encoded as a separate fragment and are surrounded by two : characters. Mention fields occur if a user types @OtherUser in their comment. A mention contains the user id of the mentioned user. All mentioned users are added to the mentioned array field, where additional user information is included. | event_typeStringThe type of the event, as a string enum. file_keyString- The key of the file that was updated.
comment_idNumber- Unique identifier for comment.
mentionsUser[]- Users that were mentioned in the comment.
order_idNumber- Only set for top level comments. The number displayed with the comment in the UI.
parent_idNumber- If present, the id of the comment to which this is the reply.
created_atString- The UTC ISO 8601 time at which the comment was left.
resolved_atString- If set, the UTC ISO 8601 time the comment was resolved.
triggered_byUser- The user that made the comment and triggered this event.
Example: { "event_type": "FILE_COMMENT", "file_key": "zH44k2FUM629Fa4EMShiHL", "file_name": "Mockup library", "comment": [ { "text": "TODO: \n" }, { "mention": "811724164054158337" }, { "text": "Change selection colors" }, ], "comment_id": "32", "mentions": [ { "id": "811724164054158337", "handle": "Evan Wallace" } ], "order_id": "23 ", "parent_id": "", "created_at": "2020-02-23T20:27:16Z", "resolved_at": "", "passcode": "secretpasscode", "timestamp": "2020-02-23T20:27:16Z", "triggered_by": { "id": "813845097374535682", "handle": "Dylan Field" }, "webhook_id": "22" }
DEV_MODE_STATUS_UPDATETriggers whenever the Dev Mode status changes for a layer in a file. This can be useful if, for example, you want to create an integration that tracks the status of designs that are being worked on in your organization. The event includes the Dev Mode status, the file_key and node_id of the layer where the status changed, and the user that made the change. It also includes any related links (Dev resources) that are applied to the layer in the file. | event_typeStringThe type of the event, as a string enum. file_keyString- The key of the file where the change occurred.
node_idString- The id of the node where the Dev Mode status changed. For example,
43:2. statusStringThe new Dev Mode status, as a string enum. NONEREADY_FOR_DEVCOMPLETED
change_messageString- If one was provided when the status was updated, a message describing the change.
related_linksDevResource[]- An array of related links that have been applied to the layer in the file.
triggered_byUser- The user that made the change and triggered this event.
Example: { "event_type": "DEV_MODE_STATUS_UPDATE", "file_key": "ABzTs1A2aFSy960zBI3nMM", "node_id": "43:2", "status": "READY_FOR_DEV", "change_message": "New rectangle", "related_links": [ { "id": 1118075899259441212, "name": "Issue BB-8", "url": "https://example.atlassian.net/jira/core/projects/BB/board?groupBy=status&selectedIssue=BB-8", "node_id": "43:2", "file_key": "ABzTs1A2aFSy960zBI3nMM" } ], "passcode": "secretpasscode", "timestamp": "2025-05-14T23:28:40Z", "triggered_by": { "id": "813845097374535682", "handle": "Dylan Field" }, "webhook_id": "434" }
