Intro to Figma Make
Figma Make is an AI-driven, prompt-to-code tool that lets you bring ideas and existing Figma designs to life as functional prototypes, web apps, and interactive UI.
Central to Figma Make is the AI chat. To get started, you use the AI chat to generate a web app or functional prototype. Using the AI chat, you can do things like specify third-party libraries that you want used, and the functionality you want implemented.
Generally, if you want to make changes to the code of your functional prototype or web app, you should do so by prompting in the AI chat. A code editor is provided if you want to make manual changes to the code. You can also paste your own code into the editor, and then converse with the AI to make changes to it. You can also add your own design system packages to enable Figma Make to generate apps and prototypes that better match your brand.
For more information about how to work with code in Figma Make, see:
