Endpoints
GET Activity Logs
Returns a list of activity log events.
This is a Tier 3 endpoint and requires the org:activity_log_read scope.
HTTP Endpoint
GET /v1/activity_logs
| Path parameters | Description |
| events |
| start_time |
| end_time |
| limit |
| order |
| Error codes | Description |
| 401 | You do not have permissions to access the requested logs |
Filtering
Add filters to your request using query string parameters. You can add combinations of path parameters to create specific queries. Here are a few examples:
Get the first 100
org_user_createandorg_user_deleteevents from the last yearcurl -H 'Authorization: Bearer <TOKEN>' 'https://api.figma.com/v1/activity_logs?limit=100&events=org_user_create,org_user_delete' -
Get all changes made to a person’s paid status for a product
curl -H 'Authorization: Bearer <TOKEN>' 'https://api.figma.com/v1/activity_logs?events=org_user_account_type_change' -
Get all the events between
2021-11-30 19:20:00 UTCand2021-12-01 23:06:40 UTCcurl -H 'Authorization: Bearer <TOKEN>' 'https://api.figma.com/v1/activity_logs?start_time=1638300000&end_time=1638400000'
Pagination
The API sorts returned events by timestamp in ascending order by default. The max number of events the endpoint can return at a time is 1000 events. You can set a lower value using the limit parameter.
If the total number of events is higher than the limit, the API will paginate the response. The JSON response will contain cursor and next_page: true, fields. The cursor encodes the last event—the most recent event—in the response.
"error": false,
"i18n": null,
"meta": {
"activity_logs": [
"cursor": "NjYzMDMxMjM5ODA4NjcvNDAwMDA=",
"next_page": true,
"status": 200
To get the next batch of events, add the cursor parameter to your new query string.
curl -H 'Authorization: Bearer <TOKEN>' 'https://api.figma.com/v1/activity_logs?cursor=NjYzMDMxMjM5ODA4NjcvNDAwMDA='
You'll likely poll this endpoint every few minutes to get the latest batch of events. You can append the cursor from the previous query to your new query. This will return any unseen events since your last query.
