Endpoints
See information about your folders, subfolders, and files within a folder.
info
Limited Access
The endpoints that require the folders:read scope cannot be used with public OAuth apps. GET folder metadata, which requires folder_metadata:read, is available to all OAuth apps.
GET team folders​
Get a list of the top-level folders within the specified team. It returns only folders visible to the authenticated user or owner of the token, accounting for direct roles, inherited access, sharing audience controls, and user groups. Each returned folder has a null parent_folder_id. Use GET folder subfolders to traverse into subfolders.
It is not possible to programmatically obtain team IDs. To obtain a team ID, navigate to the team page in the Figma file browser. The team ID is present in the URL after the word team. For example, in https://www.figma.com/files/181033233908053158/team/1535685101263221741, the team ID is 1535685101263221741.
info
This is a Tier 2 endpoint and requires the folders:read scope.
HTTP Endpoint​
GET /v2/teams/:team_id/folders
Path parametersDescription
team_id
String
ID of the team to list folders from
Error codesDescription
400Error with the request. The "message" param on the response will describe the error.
403The developer / OAuth token is invalid or expired, or does not have access to the team
404The specified team was not found
GET folder subfolders​
List the direct subfolders within a given folder (folders whose parent_folder_id equals the requested folder's ID). It returns only folders visible to the authenticated user or owner of the token.
info
HTTP Endpoint​
GET /v2/folders/:folder_id/folders
folder_id
String
ID of the parent folder to list subfolders from
403The developer / OAuth token is invalid or expired, or does not have access to the folder
404The specified folder was not found
GET folder files​
List the files directly within a given folder. It returns only files visible to the authenticated user or owner of the token.
info
HTTP Endpoint​
GET /v2/folders/:folder_id/files
folder_id
String
ID of the folder to list files from
Query parametersDescription
branch_data
Booleandefault: false
Returns branch metadata in the response for each main file with a branch inside the folder.
400Error with the request. The message param on the response will describe the error.
GET folder metadata​
Returns basic metadata about a folder — its name, thumbnail, file count, and timestamps — without enumerating its files. Use this when you need a lightweight folder preview, such as for link unfurling or search results. This is the v2 replacement for the project metadata endpoint. thumbnail_url may be null if the folder has no files.
info
This is a Tier 3 endpoint and requires the folder_metadata:read scope.
HTTP Endpoint​
GET /v2/folders/:folder_id/meta
Return value
"id": String,
"name": String,
"thumbnail_url": String,
"file_count": Number,
"updated_at": String,
"created_at": String
folder_id
String
ID of the folder to get metadata for
429The request was rate-limited
