Endpoints
Create a team, get team metadata, or invite members to a team.
GET team​
Returns metadata for a team the caller can access.
Private OAuth apps can use this endpoint for Professional, Organization, and Enterprise plans. Plan access tokens can use it for Organization and Enterprise plans.
info
This is a Tier 2 endpoint. OAuth apps require the teams:read scope.
HTTP Endpoint​
GET /v1/teams/:team_id
Path parametersDescription
team_id
String
The ID of the team.
Return value
Returns a Team.
Error codesDescription
401The access token is missing or incorrect.
403The caller does not have permission to access the team.
429The request was rate-limited.
500An internal server error occurred.
POST team​
Creates a team in the Enterprise plan associated with a private OAuth app. The app uses the authenticated user's permissions, and that user becomes the team owner. The request is subject to the same team-creation controls and permissions as team creation in Figma.
info
This is a Tier 2 endpoint, requires the teams:write scope, and is available only to private OAuth apps associated with an Enterprise plan.
HTTP Endpoint​
POST /v1/teams
Body parametersDescription
name
String
The name of the team.
description
String
Optional. A description of the team.
sharing_audience_control
String
The audience that can discover and join the team: org_view, org_edit, invite_only, workspace_view, or workspace_edit.
org_discoverability
String
Required when sharing_audience_control is invite_only and omitted otherwise. Must be hidden or discoverable.
workspace_id
String
Optional. The destination workspace. Required for workspace_view and workspace_edit.
Return value
Returns the created Team.
400The request parameters are invalid.
403The caller does not have permission to create the team.
POST team invites​
Invites people to a team in the Enterprise plan associated with a private OAuth app. The team must belong to that plan, and the authenticated user must be allowed to grant the requested role.
Each email address is processed independently. Per-address failures are returned in the errors array with a 200 response, even if invites is empty. Always inspect errors to determine which addresses could not be invited. Existing team members keep their current role when it is higher than the requested role.
info
This is a Tier 2 endpoint, requires the team_members:write scope, and is available only to private OAuth apps associated with an Enterprise plan.
HTTP Endpoint​
POST /v1/teams/:team_id/invites
team_id
String
The ID of the team to invite people to.
emails
String[]
Between 1 and 99 email addresses to invite.
role
String
The role to grant each invited member: viewer, editor, or admin. Existing roles are never downgraded.
Return value
Returns the normalized email addresses that were invited and any policy errors for individual addresses. An invitation can still require approval from an organization admin before the user joins the team.
"invites": [
"email": String,
"role": String
"errors": [
"email": String,
"error": String
400The request body, role, email address, or number of email addresses is invalid.
401The request is not authenticated.
403The token, OAuth app, or authenticated user does not have permission to invite team members.
404The team was not found, or the endpoint is not enabled.
413The request body is too large.
429The request was throttled or rate-limited. Wait before trying the request again.
