Endpoints
There are three methods provided by the Variables REST API.
GET local variables: Fetch the local variables created in the file and remote variables used in the file.
GET published variables: Fetch the variables published from this file.
POST variables: Bulk create, update, and delete local variables and variable collections.
GET local variables
This API is available to full members of Enterprise orgs.
The GET /v1/files/:file_key/variables/local endpoint lets you enumerate local variables created in the file and remote variables used in the file. Remote variables are referenced by their subscribed_id.
As a part of the Variables related API additions, the GET /v1/files/:file_key endpoint now returns a boundVariables property, containing the variableId of the bound variable. The GET /v1/files/:file_key/variables/local endpoint can be used to get the full variable or variable collection object.
Note that GET /v1/files/:file_key/variables/published does not return modes. Instead, you will need to use the GET /v1/files/:file_key/variables/local endpoint, in the same file, to examine the mode values.
This is a Tier 2 endpoint and requires the file_variables:read scope.
HTTP Endpoint
Return value
"status": Number,
"error": Boolean,
"meta": {
"variables": {
[variableId: String]: {
"id": String,
"name": String,
"key": String,
"variableCollectionId": String,
"resolvedType": 'BOOLEAN' | 'FLOAT' | 'STRING' | 'COLOR'
"valuesByMode": {
[modeId: String]: Boolean | Number | String | Color | VariableAlias,
"remote": Boolean,
"description": String,
"hiddenFromPublishing": Boolean,
"scopes": VariableScope[],
"codeSyntax": VariableCodeSyntax,
"variableCollections": {
[variableCollectionId: String]: {
"id": String,
"name": String,
"key": String,
"modes": [
"modeId": String,
"name": String,
"defaultModeId": String,
"remote": Boolean,
"variableIds": String[],
"deletedButReferenced": Boolean,
| Path parameters | Description |
| file_key |
| Error codes | Description |
| 400 | Invalid parameter. The message parameter on the response will describe the error. |
| 401 | Issue with authentication. The message parameter on the response will describe the error. |
| 403 | API is not available. Possible error messages are Limited by Figma plan, Incorrect account type, or Invalid scope. This could also indicate the developer / OAuth token is invalid or expired. |
The GET /v1/files/:file_key/variables/published endpoint returns the variables that are published from the given file.
The response for this endpoint contains some key differences compared to the GET /v1/files/:file_key/variables/local endpoint:
- Each variable and variable collection contains a
subscribed_id. - Modes are omitted for published variable collections
Published variables have two ids: an id that is assigned in the file where it is created (id), and an id that is used by subscribing files (subscribed_id). The id and key are stable over the lifetime of the variable. The subscribed_id changes every time the variable is modified and published. The same is true for variable collections.
The updatedAt fields are ISO 8601 timestamps that indicate the last time that a change to a variable was published. For variable collections, this timestamp will change any time a variable in the collection is changed.
HTTP Endpoint
Return value
"status": Number,
"error": Boolean,
"meta": {
"variables": {
"id": String,
"subscribed_id": String,
"name": String,
"key": String,
"updatedAt": String,
"id": String,
"name": String,
"key": String,
| file_key |
POST variables
This API is available to full members of Enterprise orgs. To call this API on a file, you must have edit access to the file.
The POST /v1/files/:file_key/variables endpoint lets you bulk create, update, and delete variables and variable collections.
The request body supports the following 4 top-level arrays. Changes from these arrays will be applied in the below order, and within each array, by array order.
variableCollections: For creating, updating, and deleting variable collections.variableModes: For creating, updating, and deleting modes within variable collections.- Each collection can have a maximum of 40 modes
- Mode names cannot be longer than 40 characters
variables: For creating, updating, and deleting variables.- Each collection can have a maximum of 5000 variables
- Variable names must be unique within a collection and cannot contain certain special characters such as
variableModeValues: For setting a variable value under a specific mode.- When setting aliases, a variable cannot be aliased to itself or form an alias cycle
Temporary ids can be used to reference an object later in the same POST request body. They can be used at create time in the id property of variable collections, modes, variables, and in the initialModeId property of variable collections. They are scoped to a single request body, and must be unique within the body. The mapping of temporary ids to real ids is returned in the response.
This endpoint has the following key behaviors:
- The request body must be 4MB or less.
- Must include an
actionproperty for collections, modes, and variables to tell the API whether to create, update, or delete the object. - When creating a collection, mode, or variable, you can include a temporary
idthat can be referenced in dependent objects in the same request. For example, you can create a new collection with the idmy_new_collection. You can then setvariableCollectionIdtomy_new_collectionin new modes or variables. Temporary ids must be unique in the request body. - New collections always come with one mode. You can reference this mode by setting
initialModeIdto a temporary id in the request body. This is useful if you want to set values for variables in the mode in thevariableModeValuesarray.- The
tempIdToRealIdarray returns a mapping of the temporary ids in the request, to the real ids of the newly created objects.
- The
- When adding new modes or variables, default variable values will be applied, consistent with what happens in the UI.
- Everything to be created, updated, and deleted in the request body is treated as one atomic operation. If there is any validation failure, you will get a 400 status code response, and no changes will be persisted.
- You will not be able to update remote variables or variable collections. You can only update variables in the file where they were originally created.
Warning: If a string variable is bound to a text node content in the same file, and the text node uses a shared font in the organization, that variable cannot be updated and will result in a 400 response.
The below types are accepted in the request body for this endpoint:
| Name | Properties |
VariableCollectionChangeAn object that contains details about the desired VariableCollection change. |
VariableModeChangeAn object that contains details about the desired variable mode change. |
VariableChangeAn object that represents the action you want to take with a variable. |
VariableModeValueAn object that represents a value for a given mode of a variable. |
This is a Tier 3 endpoint and requires the file_variables:write scope.
HTTP Endpoint
Return value
"status": Number,
"error": Boolean,
"meta": {
"tempIdToRealId": {
[temporaryId: String]: String
| file_key |
| Body parameters | Description |
| variableCollections |
| variableModes |
| variables |
| variableModeValues |
| 403 | API is not available. Possible error messages are Limited by Figma plan, Incorrect account type, Invalid scope, Insufficient file permissions, or API only available for design files. This could also indicate the developer / OAuth token is invalid or expired. |
| 404 | The specified file was not found. |
| 413 | Request payload too large. The max allowed body size is 4MB. |
Examples
The following examples are request bodies for the POST variables endpoint.
To create a new variable collection:
"variableCollections": [
"action": "CREATE",
"name": "Example variable collection"
To create a variable in an existing variable collection:
"variables": [
"action": "CREATE",
"name": "New Variable",
"variableCollectionId": "VariableCollectionId:1:2",
"resolvedType": "FLOAT"
To create a variable mode in an existing variable collection:
"variableModes": [
"action": "CREATE",
"name": "New Mode",
To set a value for an existing variable:
"variableModeValues": [
"variableId": "VariableID:2:3",
"modeId": "1:0",
"value": { "r": 1, "g": 0, "b": 0 }
To set a variable alias to an existing variable:
"variableId": "VariableID:2:4",
"modeId": "1:0",
"value": { "type": "VARIABLE_ALIAS", "id": "VariableID:1:3" }
To rename an existing variable:
"variables": [
"action": "UPDATE",
"id": "VariableID:1:3",
To set code syntax for a variable:
"variables": [
"action": "UPDATE",
"codeSyntax": { "WEB": "variable-name", "ANDROID": "variableName", "iOS": "variableName" }
To rename an existing variable mode:
"variableModes": [
"action": "UPDATE",
"id": "1:0",
"name": "New Mode Name",
To create a new variable collection that contains a variable:
"action": "CREATE",
"id": "my_variable_collection", // sets a temporary id for the variable collection
"name": "New Variable Collection",
"initialModeId": "my_mode" // sets a temporary id for the initial variable mode
"variableModes": [
"action": "UPDATE",
"id": "my_mode",
"name": "My Mode", // rename the initial variable mode
"variableCollectionId": "my_variable_collection" // uses the temporary id of the variable collection
"variables": [
"action": "CREATE",
"id": "my_variable",
"name": "float variable",
"resolvedType": "FLOAT",
"variableId": "my_variable", // uses the temporary id of the variable
"modeId": "my_mode", // uses the temporary id of the variable mode
"value": 100
To delete a variable mode:
"variableModes": [
"action": "DELETE",
"id": "2:0",
"variableCollectionId": "VariableCollectionId:2:3"
