createComponentFromNode
info
This API is only available in Figma Design
Creates a component from an existing node, preserving all of its properties and children. The behavior is similar to using the Create component button in the toolbar.
Signature
createComponentFromNode(node: SceneNode): ComponentNode
Remarks
To create a brand new component instead, use figma.createComponent.
There are many restrictions on what nodes can be turned into components. For example, the node cannot be a component or component set and cannot be inside a component, component set, or instance.
If you try to create a component from a node that cannot be turned into a component, then the function will throw a Cannot create component from node error.
Create a component from a node
const frame = figma.createFrame()
const component = figma.createComponentFromNode(frame)
