mode
Return the context the plugin is current running in.
default- The plugin is running as a normal plugin.textreview- The plugin is running to provide text review functionality.inspect- The plugin is running in the Inspect panel in Dev Mode.codegen- The plugin is running in the Code section of the Inspect panel in Dev Mode.linkpreview- The plugin is generating a link preview for a Dev resource in Dev Mode.auth- The plugin is running to authenticate a user in Dev Mode.
caution
The linkpreview and auth modes are only available to partner and Figma-owned plugins.
Signature
mode: 'default' | 'textreview' | 'inspect' | 'codegen' | 'linkpreview' | 'auth' [readonly]
Remarks
Here’s a simplified example where you can create an if statement in a plugin that has one set of functionality when it is run in Dev Mode, and another set of functionality when run in Figma design:
Code sample to determine editorType and mode
if (figma.editorType === "dev") {
// Read the document and listen to API events
if (figma.mode === "inspect") {
// Running in inspect panel mode
} else if (figma.mode === "codegen") {
// Running in codegen mode
} else if (figma.editorType === "figma") {
// If the plugin is run in Figma design, edit the document
if (figma.mode === 'textreview') {
// Running in text review mode
} else if (figma.editorType === "figjam") {
// Do FigJam only operations
