notify
Shows a notification on the bottom of the screen.
Signature
notify(message: string, options?: NotificationOptions): NotificationHandler
Parameters
message
The message to show. It is limited to 100 characters. Longer messages will be truncated.
options
An optional argument with the following optional parameters:
interface NotificationOptions {
timeout?: number;
error?: boolean;
onDequeue?: (reason: NotifyDequeueReason) => void
button?: {
text: string
action: () => boolean | void
timeout: How long the notification stays up in milliseconds before closing. Defaults to 3 seconds when not specified. Set the timeout toInfinityto make the notification show indefinitely until the plugin is closed.error: If true, display the notification as an error message, with a different color.onDequeue: A function that will run when the notification is dequeued. This can happen due to the timeout being reached, the notification being dismissed by the user or Figma, or the user clicking the notification'sbutton.- The function is passed a
NotifyDequeueReason, which is defined as the following:
type NotifyDequeueReason = 'timeout' | 'dismiss' | 'action_button_click'
button: An object representing an action button that will be added to the notification.text: The message to display on the action button.action: The function to execute when the user clicks the button. If this function returnsfalse, the message will remain when the button is clicked. Otherwise, clicking the action button dismisses the notify message.
Remarks
The notify API is a convenient way to show a message to the user. These messages can be queued.
If the message includes a custom action button, it will be closed automatically when the plugin closes.
Calling figma.notify returns a NotificationHandler object. This object contains a single handler.cancel() method that can be used to remove the notification before it times out by itself. This is useful if the notification becomes no longer relevant.
interface NotificationHandler {
cancel: () => void
An alternative way to show a message to the user is to pass a message to the figma.closePlugin function.
