showUI
Enables you to render UI to interact with the user, or simply to access browser APIs. This function creates a modal dialog with an <iframe> containing the HTML markup in the html argument.
Signature
showUI(html: string, options?: ShowUIOptions): void
Parameters
html
The HTML to insert into the iframe. You can pass in the HTML code as a string here, but this will often be the global value __html__.
options
An object that may contain the following optional parameters:
visible: Whether the UI starts out displayed to the user. Defaults totrue. You can usefigma.ui.show()andfigma.ui.hide()to change the visibility later.width: The width of the UI. Defaults to 300. Minimum is 70. Can be changed later usingfigma.ui.resize(width, height)height: The height of the UI. Defaults to 200. Minimum is 0. Can be changed later usingfigma.ui.resize(width, height)title: The title of the UI window. Defaults to the plugin name.position: The position of the UI window. Defaults to the last position of the iframe or the center of the viewport. If specified, expects an X/Y coordinate in the canvas space (i.e matches x/y values returned by<PluginNode>.xand<PluginNode>.y)themeColors: Defaults tofalse. When enabled, CSS variables will be added to the plugin iframe to allow support for light and dark themes.
If the position specified is outside of the user's viewport, the iframe will be moved so that it remains in the user's viewport.
Remarks
The easiest way to use this API is to load the HTML file defined in the manifest. This enables writing a separate HTML file which can be accessed through the __html__ global variable.
If the <iframe> UI is already showing when this function is called, the previous UI will be closed before the new one is displayed.
Usage Examples
figma.showUI(
"<b>Hello from Figma</b>",
{ width: 400, height: 200, title: "My title" }
figma.showUI(
{ width: 400, height: 200, title: "My title", position: { x: 100, y: 100 } }
figma.showUI(__html__)
