solidPaint
Creates a SolidPaint object, assigning color and opacity from a variety of common color encodings.
Accepted color formats include CSS color strings with hex, rgb(), hsl(), or lab() encodings, as well as RGB and RGBA objects. The resulting alpha value will be applied to the SolidPaint's opacity property, which defaults to 1 (opaque) if not specified. If a string encoding cannot be parsed, an error will be thrown.
Optionally, you can provide a set of overrides for any of the non-color properties of the SolidPaint object. This is useful for modifying the color of an existing SolidPaint while preserving its other properties.
Examples:
// Set the current page background to red
figma.currentPage.backgrounds = [figma.util.solidPaint("#FF0000")]
// Modify an existing SolidPaint with new color and opacity
if (node.fills[0].type === 'SOLID') {
const updated = figma.util.solidPaint('#FF00FF88', node.fills[0])
You can alias this function for more concise code:
const solidPaint = figma.util.solidPaint
figma.currentPage.backgrounds = [solidPaint("#FF0000")]
const updated = solidPaint('#FF00FF88', node.fills[0])
Signature
solidPaint(color: string | RGB | RGBA, overrides?: Partial<SolidPaint>): SolidPaint
Parameters
color
A CSS color string, RGB object, or RGBA object.
overrides
An optional object that allows you to specify additional SolidPaint properties, aside from color. This is useful for modifying the color of a pre-existing SolidPaint object.
