on
A plugin for code generation needs to call figma.codegen.on('generate') to register a callback
that will be called when a user's selection changes in Dev Mode. This callback
should return an array of JSON objects that represent the sections in the
Inspect panel. The callback has a 15 second timeout and returns an error if it times out. For more
information, see the remarks.
Signature
on(type: 'generate', callback: (event: CodegenEvent) => Promise<CodegenResult[]> | CodegenResult[]): void
on(type: 'preferenceschange', callback: (event: CodegenPreferencesEvent) => Promise<void>): void
Parameters
type
The type of event to add the callback for: 'generate' or 'preferenceschange'.
callback
The callback that is called when the event is triggered.
Remarks
This callback can be async if your plugin needs to do some data fetching or other async operation to generate code.
figma.showUI is not allowed within the generate callback. Instead, if figma.showUI is required in the generate callback, the showUI call should be moved outside of the callback and figma.ui.postMessage should be used within the callback instead. This ensures that the plugin is able to handle concurrent "generate" events.
A plugin can also register a callback to handle events when codegen preferences are modified. This is useful for codegenPreferences that need to open an iframe to get more user input.
Only preferences with itemType: "action" will trigger the `"preferenceschange"`` callback.
The callback has a 15 second timeout. If the callback registered by figma.codegen.on('generate')
doesn't return a value within 15 seconds (for example, if the array of JSON objects takes too long to
construct), the operation ends and an error message is sent to the console:
code generation timed out after 15 seconds
Additionally, a notification appears in the Code section of the Inspect panel to alert the plugin's user of the error:
<Plugin name> ran into an issue
This plugin is created by a third party and not
maintained by Figma, so to give feedback please
reach out to the developer.
The error in the Inspect panel includes a link to your plugin's community page.
