counterAxisAlignItems
Applicable only on "HORIZONTAL" or "VERTICAL" auto-layout frames. Determines how the auto-layout frame’s children should be aligned in the counter axis direction.
Supported on:
Signature
counterAxisAlignItems: 'MIN' | 'MAX' | 'CENTER' | 'BASELINE'
Remarks
Changing this property will cause all the children to update their x and y values.
- In horizontal auto-layout frames,
“MIN”and“MAX”correspond to top and bottom respectively. - In vertical auto-layout frames,
“MIN”and“MAX”correspond to left and right respectively. "BASELINE"can only be set on horizontal auto-layout frames, and aligns all children along the text baseline.
The corresponding property for the primary axis direction is primaryAxisAlignItems.
Horizontal auto-layout frame with different counterAxisAlignItems values
(async () => {
const parentFrame = figma.createFrame()
const text = figma.createText()
await figma.loadFontAsync(text.fontName)
text.characters = 'asdf'
// Make the text taller so we can see how text baseline alignment works
text.lineHeight = {unit: 'PERCENT', value: 300}
// Auto-layout frame will have 2 children: a frame and a text node
parentFrame.appendChild(figma.createFrame())
parentFrame.appendChild(text)
parentFrame.layoutMode = 'HORIZONTAL'
// Make the parent frame taller so we can see the effects of
// the different counterAxisAlignItems values
parentFrame.resize(200, 150)
// Parent frame
// || Child 1 ||asdf| |
parentFrame.counterAxisAlignItems = 'MIN'
// Parent frame
parentFrame.counterAxisAlignItems = 'MAX'
// Parent frame
parentFrame.counterAxisAlignItems = 'CENTER'
// Parent frame
// || Child 1 || | |
// || ||asdf| |
parentFrame.counterAxisAlignItems = 'BASELINE'
