counterAxisSizingMode
Applicable only on auto-layout frames. Determines whether the counter axis has a fixed length (determined by the user) or an automatic length (determined by the layout engine).
Supported on:
Signature
counterAxisSizingMode: 'FIXED' | 'AUTO'
Remarks
Auto-layout frames have a primary axis, which is the axis that resizes when you add new items into the frame. For example, frames with "VERTICAL" layoutMode resize in the y-axis.
The other axis is called the counter axis.
"FIXED": The counter axis length is determined by the user or plugins, unless thelayoutAlignis set to “STRETCH” orlayoutGrowis 1."AUTO": The counter axis length is determined by the size of the children. If set, the auto-layout frame will automatically resize along the counter axis to fit its children.
Note: “AUTO” cannot be used in any axes where layoutAlign = “STRETCH” or layoutGrow = 1. Either use “FIXED” or disable layoutAlign/layoutGrow.
Horizontal auto-layout frame with different counterAxisSizingMode values
const parentFrame = figma.createFrame()
const child2 = figma.createFrame()
// Make the second child 200px high instead of the default 100px
child2.resize(100, 200)
parentFrame.appendChild(figma.createFrame())
parentFrame.appendChild(child2)
parentFrame.layoutMode = 'HORIZONTAL'
// Parent frame
// || Child 1 || Child 2 ||
parentFrame.counterAxisSizingMode = 'FIXED' // Child 2 is clipped
// Parent frame
parentFrame.counterAxisSizingMode = 'AUTO'
