findAllWithCriteria
Searches this entire subtree (this node's children, its children's children, etc). Returns all nodes that satisfy all of specified criteria.
If the manifest contains "documentAccess": "dynamic-page", and the node is a PageNode, you must first call loadAsync to access this function.
Supported on:
Signature
findAllWithCriteria<T extends NodeType[]>(criteria: FindAllCriteria<T>): Array<{ type: T[number] } & SceneNode>
Parameters
criteria
An object of type FindAllCriteria that specifies the search criteria. The following criterias are currently supported:
- Nodes with specific
types - Nodes with
SharedPluginDataby their namespace and keys. - Nodes with
PluginDataby their keys. - A combination of any of the above.
Remarks
This is a faster but more limited search compared to findAll, which lets you search nodes based on any logic you can include in a callback.
When paired with figma.skipInvisibleInstanceChildren = true, this method can be hundreds of times faster in large documents with tens of thousands of nodes.
The return value is narrowly typed to match the provided types, which makes it much easier to use node-type-specific properties. For example, node.findAllWithCriteria({ types: ['TEXT'] }) will return TextNode[] instead of the more generic SceneNode[] from findAll.
Nodes are included in back-to-front order, which is the same order as in findAll. Parents always appear before their children, and children appear in same relative order before their children, and children appear in same relative order as in the children array.
This traversal method is known as "pre-order traversal".
The node this method is called on is not included.
Example Usages
Find by node type
// Find all component and component set nodes in the current
// page
const nodes = figma.currentPage.findAllWithCriteria({
types: ['COMPONENT', 'COMPONENT_SET']
// Find all text nodes in the current page
types: ['TEXT']
Find by plugin data
// Find all nodes in the current page with plugin data
// for the current plugin.
pluginData: {}
// for the current plugin with keys "a" or "b"
pluginData: {
keys: ["a", "b"]
Find by shared plugin data
// Find all nodes in the current page with shared plugin data
// stored on the "bar" namespace
sharedPluginData: {
namespace: "bar"
// stored on the "bar" namespace and keys "a" or "b"
sharedPluginData: {
namespace: "bar",
keys: ["a", "b"]
Combining criterias
You can combine multiple criterias for further narrow your search.
// Find all text nodes in the current page with plugin data
types: ["TEXT"],
pluginData: {}
// Find all text nodes in the current page with shared plugin data
types: ["TEXT"],
sharedPluginData: {
namespace: "bar"
