gridColumnCount
Applicable only on auto-layout frames with layoutMode set to "GRID". Determines the number of columns in the grid.
Signature
gridColumnCount: number
Remarks
If the setter for this value is called on a grid with a value less than 1, it will throw an error.
Users cannot remove columns from a grid if they are occupied by children, so if you try to reduce the count of columns in a grid and some of those columns have children, it will throw an error.
By default, when the column count is increased, the new columns will be added as GridTrackSize objects with type "FLEX". If you want to change the type of the new columns, you can use the setters on GridTrackSize objects returned by gridRowSizes or gridColumnSizes.
