primaryAxisAlignItems
Applicable only on "HORIZONTAL" or "VERTICAL" auto-layout frames. Determines how the auto-layout frame’s children should be aligned in the primary axis direction.
Supported on:
Signature
primaryAxisAlignItems: 'MIN' | 'MAX' | 'CENTER' | 'SPACE_BETWEEN'
Remarks
Changing this property will cause all the children to update their x and y values.
- In horizontal auto-layout frames,
“MIN”and“MAX”correspond to left and right respectively. - In vertical auto-layout frames,
“MIN”and“MAX”correspond to top and bottom respectively. “SPACE_BETWEEN”will cause the children to space themselves evenly along the primary axis, only putting the extra space between the children.
The corresponding property for the counter axis direction is counterAxisAlignItems.
Horizontal auto-layout frame with different primaryAxisAlignItems values
const parentFrame = figma.createFrame()
parentFrame.appendChild(figma.createFrame())
parentFrame.layoutMode = 'HORIZONTAL'
// Make the parent frame wider so we can see the effects of
// the different primaryAxisAlignItems values
parentFrame.resize(300, 100)
// Parent frame
// | | Child 1 || Child 2 | |
parentFrame.primaryAxisAlignItems = 'MIN'
// Parent frame
// | | Child 1 || Child 2 ||
parentFrame.primaryAxisAlignItems = 'MAX'
// Parent frame
parentFrame.primaryAxisAlignItems = 'CENTER'
// Parent frame
// || Child 1 | | Child 2 ||
parentFrame.primaryAxisAlignItems = 'SPACE_BETWEEN'
