on
Registers an callback that will be called when an event happens in the editor. Current supported events are:
- The selection on the current page changed.
- The current page changed.
- The document has changed.
- An object from outside Figma is dropped onto the canvas
- The plugin has started running.
- The plugin closed.
- The timer has started running.
- The timer has paused.
- The timer has stopped.
- The timer is done.
- The timer has resumed.
Signature
on(type: ArgFreeEventType, callback: () => void): void
on(type: 'run', callback: (event: RunEvent) => void): void
on(type: 'drop', callback: (event: DropEvent) => boolean): void
on(type: 'documentchange', callback: (event: DocumentChangeEvent) => void): void
on(type: 'slidesviewchange', callback: (event: SlidesViewChangeEvent) => void): void
on(type: 'canvasviewchange', callback: (event: CanvasViewChangeEvent) => void): void
on(type: 'textreview', callback: (event: TextReviewEvent) => Promise<TextReviewRange[]> | TextReviewRange[]): void
on(type: 'stylechange', callback: (event: StyleChangeEvent) => void): void
Parameters
type
A string identifying the type of event that the callback will be called on.
This is either an ArgFreeEventType, run, drop, or documentchange. The run event callback will be passed a RunEvent. The drop event callback will be passed a DropEvent. The documentchange event callback will be passed a DocumentChangeEvent.
type ArgFreeEventType =
"selectionchange" |
"currentpagechange" |
"close" |
"timerstart" |
"timerstop" |
"timerpause" |
"timerresume" |
"timeradjust" |
"timerdone"
callback
A function that will be called when the event happens.
If type is 'run', then this function will be passed a RunEvent.
If type is 'drop', then this function will be passed a DropEvent.
If type is 'documentchange', then this function will be passed a DocumentChangeEvent.
Otherwise nothing will be passed in.
Remarks
This API tries to match Node.js conventions around similar .on APIs.
It's important to understand that the .on API runs the callbacks asynchronously. For example:
figma.on("selectionchange", () => { console.log("changed") })
console.log("before")
figma.currentPage.selection = []
console.log("after")
// Output:
// "before"
// "after"
// "changed"
The asynchronous nature of these APIs have a few other implications.
The callback will not necessarily be called each time the event happens. For example, this will only trigger the event once:
figma.currentPage.selection = [figma.createRectangle()]
figma.currentPage.selection = [figma.createFrame()]
Nor will the ordering of the event trigger and event registration affect whether the callback is called.
figma.on("selectionchange", () => { "this will get called!" })
Available event types
"currentpagechange"
This event will trigger when the user navigates to a different page, or when the plugin changes the value of figma.currentPage.
"selectionchange"
This event will trigger when the selection of the current page changes. This can happen:
- By user action.
- Due to plugin code.
- When the current page changes (a
"currentpagechange"event always triggers a"selectionchange"event). - When a selected node is deleted.
- When a selected node becomes the child of another selected node (in which case it is considered indirectly selected, and is no longer in
figma.currentPage.selection)
Note also that changing the selection via the plugin API, then changing it back to its previous value immediately still triggers the event.
"documentchange"
If the plugin manifest contains "documentAccess": "dynamic-page", you must first call figma.loadAllPagesAsync to access this event. Because this may introduce a loading delay, consider using more granular alternatives, such as the "stylechange" event, or using PageNode.on with the "nodechange" event.
This event will trigger when a change is made to the currently open file. The event will be called when nodes/styles are either added, removed, or changed in a document.
The callback will be passed with a DocumentChangeEvent with the below interface:
interface DocumentChangeEvent {
documentChanges: DocumentChange[]
Note that DocumentChangeEvent has a documentChanges property with an array of DocumentChanges. Figma will not call the 'documentchange' callback synchronously and will instead batch the updates and send them to the callback periodically.
There are 6 different DocumentChange types that we currently notify on and we might add more in the future. Each of these changes has a type property to distinguish them:
| Change | type property | Description |
CreateChange | 'CREATE' | A node has been created in the document. If a node with nested children is being added to the document a CreateChange will only be made for the highest level parent that was added to the document. |
DeleteChange | 'DELETE' | A node has been removed from the document. If a node with nested children is being removed from the document a DeleteChange will only be made for the highest level parent that was removed from the document. |
PropertyChange | 'PROPERTY_CHANGE' | A property of a node has changed. |
StyleCreateChange | 'STYLE_CREATE' | A style has been added to the document. |
StyleDeleteChange | 'STYLE_DELETE' | A style has been removed from the document. |
StylePropertyChange | 'STYLE_PROPERTY_CHANGE' | A style has had a property changed. |
Special cases
We currently never notify a 'documentchange' listener in the following scenarios:
- if the change was caused directly by your plugin in a
documentchangecallback - if an instance sublayer was updated by a change to a main component
- if a node was updated as a result of a style changing
Example
Here is an example of exhaustively checking changes to the document and logging them to the console.
figma.on("documentchange", (event) => {
for (const change of event.documentChanges) {
switch (change.type) {
case "CREATE":
console.log(
`Node ${change.id} created by a ${change.origin.toLowerCase()} user`
break;
case "DELETE":
console.log(
`Node ${change.id} deleted by a ${change.origin.toLowerCase()} user`
break;
case "PROPERTY_CHANGE":
for (const prop of change.properties) {
console.log(
`Node ${
change.id
} had ${prop} changed by a ${change.origin.toLowerCase()} user`
break;
case "STYLE_CREATE":
console.log(
`Style ${change.id} created by a ${change.origin.toLowerCase()} user`
break;
case "STYLE_DELETE":
console.log(
`Style ${change.id} deleted by a ${change.origin.toLowerCase()} user`
break;
case "STYLE_PROPERTY_CHANGE":
console.log(
`Style ${
change.id
break;
For a more involved example see our plugin samples on GitHub.
"textreview"
This event is only available to plugins that have the "textreview" capability in their manifest.json and the plugin is running in text review mode.
"textreview" events allow plugins to review text in a document and act as either a replacement or a supplement to native spell check.
This event is triggered periodically when the user is typing in a text node. The callback will be passed with a TextReviewEvent with the below interface:
interface TextReviewEvent {
text: string
The text property is the text that the user has currently typed into the node.
A "textreview" event listener should return a promise that resolves to an array of TextReviewRange objects. Each TextReviewRange object represents a single range of text that should be marked as either an error or a suggestion. The TextReviewRange interface is defined as:
type TextReviewRange = {
start: number
end: number
suggestions: string[]
color?: 'RED' | 'GREEN' | 'BLUE'
The start property is the index of the first character in the range. The end property is the index of the last character in the range. The suggestions property is an array of strings that represent the suggestions for the range. The color property is optional and can be used to change the color of the underline that is drawn under the range. If no color is specified the underline will be red.
For more information read our in depth guide on text review plugins.
"drop"
This event will trigger when objects outside Figma (such as elements from other browser windows, or files from the local filesystem) are dropped onto the canvas.
It can also be triggered by a special pluginDrop message sent from the UI. See the Triggering drop events from the UI section for more details.
The callback will be passed a DropEvent with the below interface. It should return false if it wants to handle the particular drop and stop Figma from performing the default drop behavior.
interface DropEvent {
node: BaseNode | SceneNode
x: number
y: number
absoluteX: number
absoluteY: number
items: DropItem[]
files: DropFile[]
dropMetadata?: any
- The
nodeproperty contains the node where the drop landed. This will sometimes be the page node if the drop didn't land on anything in the canvas, or if target node is locked or cannot be a parent of another node. - The
xandyproperties are coordinates relative to the node drop target - The
absoluteXandabsoluteYproperties are absolute canvas coordinates - The
itemsproperty is an array ofDropItemobjects. You will see multiple objects if a drop contains multiple, non-file data types. If there are no data items, this array will be empty. - The
filesproperty is an array of dropped files represented asDropFileobjects. If no files are present, this array will be empty. - The
dropMetadataproperty comes from drop events explicitly triggered by the UI.
Items and files will conform to the below interfaces:
interface DropItem {
type: string // e.g. "text/html", "text/uri-list", etc...
data: string
interface DropFile {
name: string // file name
type: string // e.g. "image/png"
getBytesAsync(): Promise<Uint8Array> // get raw file bytes
getTextAsync(): Promise<string> // get text assuming file is UTF8-encoded
See the Icon Drag-and-Drop and PNG Crop examples in the figma/plugin-samples repository for plugins that implement this API.
UI Recommendations
When the plugin registers a drop callback, it should give the user instructions with either text in the plugin UI or figma.notify() (if the plugin does not show a UI) telling them what to do.
figma.notify() can be called with the timeout option set to Infinity to make the notification show for as long as the plugin is open.
"close"
This event will trigger when the plugin is about to close, either from a call to figma.closePlugin() or the user closing the plugin via the UI.
This is a good place to run cleanup actions. For example, some plugins add UI elements in the canvas by creating nodes. These UI elements should be deleted when the plugin is closed. Note that you don't need to call figma.closePlugin() again in this function.
You should use this API only if strictly necessary, and run as little code as possible in the callback when doing so. When a user closes a plugin, they expect it to be closed immediately. Having long-running actions in the closing callback prevents the plugin for closing promptly.
This is also not the place to run any asynchronous actions (e.g. register callbacks, using await, etc). The plugin execution environment will be destroyed immediately when all the callbacks have returned, and further callbacks will not be called.
"run"
This event is triggered when a plugin is run. For plugins with parameters, this happens after all parameters have been enter by the user in the quick action UI. For all other plugins this happens immediately after launch.
The callback will be passed a RunEvent that looks like:
interface RunEvent {
parameters?: ParameterValues
command: string
- The
parametersproperty is of typeParameterValues, and contains the value entered for each parameter. - The
commandargument is the same asfigma.command, but provided here again for convenience.
Handling the run event is only required for plugins with parameters. For all plugins it can still be a convenient spot to put your top level code, since it is called
on every plugin run.
"stylechange"
Triggered when any styles in the document change.
The callback will receive a StyleChangeEvent with the below interface:
interface StyleChangeEvent {
styleChanges: StyleChange[]
There are 3 different StyleChange types. Each of these changes has a type property to distinguish them:
"timerstart"
This event will trigger when somebody starts a timer in the document. This can happen either by a user (either the current user or a multiplayer user) starting the timer from the UI, or triggered by plugin code. To inspect the current state of the timer when this event fires, use the figma.timer interface. For example:
figma.on("timerstart", () => console.log(figma.timer.remaining))
figma.timer.start(300)
// Output:
// 300
"timerpause"
Triggered when a timer that is running is paused.
"timerstop"
Triggered when the timer is stopped.
"timerdone"
Triggered when the timer is running and reaches 0 time remaining.
"timerresume"
Triggered when a timer that is paused is resumed.
"timeradjust"
Triggered when the total time on the timer changes. From the UI, it is only possible to add time to the timer. However, plugin code can both add and remove time from a running timer.
