insertChild
Adds a new child at the specified index in the children array.
If the manifest contains "documentAccess": "dynamic-page", and the node is a PageNode, you must first call loadAsync to access this function.
Signature
insertChild(index: number, child: SceneNode): void
Parameters
index
Determines where the new layer gets inserted. For example, suppose a group has layers A, B, C, where C is the top-most layer.
  • insertChild(0, D) gives a group with layers D, A, B, C
  • insertChild(1, D) gives a group with layers A, D, B, C
  • insertChild(2, D) gives a group with layers A, B, D, C
  • insertChild(3, D) gives a group with layers A, B, C, D
  • insertChild(4, D) throws an error since the group originally only has 3 children
child
The node to be inserted.
Remarks
Reparenting nodes is subject to many restrictions. For example, some nodes cannot be moved, others would break the document if moved. Below are possible exceptions that can be thrown if the operation is invalid.
If this is called on an auto-layout frame, calling this function can cause this layer to be resized and children to be moved.
Possible error cases
Cannot insert node at index greater than the number of existing siblings
Cannot move node. Node is the scene root, which cannot be reparented
Cannot move node. Doing so would create a parenting cycle
Cannot move node. The root node cannot have children of type other than PAGE
Cannot move node. Nodes other than the root node cannot have children of type PAGE
Cannot move node. New parent is of a type that cannot have children
Cannot move node. New parent is a internal, readonly-only node
Cannot move node. Node is an internal, readonly-only node
Cannot move node. New parent is an instance or is inside of an instance
Cannot move node. Node is inside of an instance
Cannot move node. Reparenting would create a component cycle
Cannot move node. Reparenting would create a component inside a component
Cannot move node. Reparenting would create a component set cycle
Cannot move node. A COMPONENT_SET node cannot have children of type other than COMPONENT
Cannot move node. PageDivider cannot have children
Cannot move node. Node is not allowed SLOT node
