resizeWithoutConstraints
Resizes the node. Children of the node are never resized, even if those children have constraints. If the parent has auto-layout, causes the parent to be resized (this constraint cannot be ignored).
Supported on:
Signature
resizeWithoutConstraints(width: number, height: number): void
Parameters
width
New width of the node. Must be >= 0.01
height
New height of the node. Must be >= 0.01, except for LineNode which must always be given a height of exactly 0.
Remarks
This function will not cause its children to resize. Use resize if you need to apply constraints.
⚠️ If this node is a text node with a missing font, the text node will be resized but the text will not re-layout until the next time the text node is opened on a machine that has the font. This can cause the text node to re-layout immediately and be surprising to your user. Consider checking the text node property hasMissingFont before using this function.
Ignores targetAspectRatio. If targetAspectRatio has been set, it will be updated to correspond to the post-resize value.
