exportAsync
Exports the node as an encoded image.
If the manifest contains "documentAccess": "dynamic-page", and the node is a PageNode, you must first call loadAsync to access this function.
Supported on:
- BooleanOperationNode
- CodeBlockNode
- ComponentNode
- ComponentSetNode
- ConnectorNode
- EllipseNode
- EmbedNode
- FrameNode
- GroupNode
- HighlightNode
- InstanceNode
- InteractiveSlideElementNode
- LineNode
- LinkUnfurlNode
- MediaNode
- PageNode
- PolygonNode
- RectangleNode
- SectionNode
- ShapeWithTextNode
- SliceNode
- SlideGridNode
- SlideNode
- SlideRowNode
- SlotNode
- StampNode
- StarNode
- StickyNode
- TableNode
- TextNode
- TextPathNode
- TransformGroupNode
- VectorNode
- WashiTapeNode
- WidgetNode
Signature
exportAsync(settings?: ExportSettings): Promise<Uint8Array>
exportAsync(settings: ExportSettingsSVGString): Promise<string>
exportAsync(settings: ExportSettingsREST): Promise<Object>
Parameters
settings
When this parameter is absent, this function defaults to exporting as a PNG at 1x resolution.
Note that the result is a Uint8Array, representing the bytes of the image file (encoded in the specified format).
Create a hexagon, export as PNG, and place on canvas
(async () => {
const polygon = figma.createPolygon()
polygon.pointCount = 6
polygon.fills = [{ type: 'SOLID', color: { r: 1, g: 0, b: 0 } }]
// Export a 2x resolution PNG of the node
const bytes = await polygon.exportAsync({
format: 'PNG',
constraint: { type: 'SCALE', value: 2 },
// Add the image onto the canvas as an image fill in a frame
const image = figma.createImage(bytes)
const frame = figma.createFrame()
frame.x = 200
frame.resize(200, 230)
frame.fills = [{
imageHash: image.hash,
scaleMode: "FILL",
scalingFactor: 1,
type: "IMAGE",
Export a VectorNode as an SVG string
(async () => {
// Create a triangle using the VectorPath API
const vector = figma.createVector()
vector.vectorPaths = [{
windingRule: "EVENODD",
data: "M 0 100 L 100 100 L 50 0 Z",
// Export the vector to SVG
const svg = await vector.exportAsync({ format: 'SVG_STRING' })
console.log(svg);
Export a node as a JSON object
(async () => {
const json = await figma.currentPage.selection[0].exportAsync({format: 'JSON_REST_V1'})
// Return a JSON object in the same format as the Figma REST API response
console.log(json.document)
