removed
Returns true if this node has been removed since it was first accessed. If your plugin stays open for a while and stores references to nodes, you should write your code defensively and check that the nodes haven't been removed by the user.
Supported on:
- BooleanOperationNode
- CodeBlockNode
- ComponentNode
- ComponentSetNode
- ConnectorNode
- DocumentNode
- EllipseNode
- EmbedNode
- FrameNode
- GroupNode
- HighlightNode
- InstanceNode
- InteractiveSlideElementNode
- LineNode
- LinkUnfurlNode
- MediaNode
- PageNode
- PolygonNode
- RectangleNode
- SectionNode
- ShapeWithTextNode
- SliceNode
- SlideGridNode
- SlideNode
- SlideRowNode
- SlotNode
- StampNode
- StarNode
- StickyNode
- TableNode
- TextNode
- TextPathNode
- TransformGroupNode
- VectorNode
- WashiTapeNode
- WidgetNode
Signature
removed: boolean [readonly]
Remarks
A node can be removed for any number of reasons. Some examples:
- Your plugin called node.remove() on it
- Someone else deleted the node using multiplayer
- The user triggered an undo action and the node was removed
- The user simply deleted the node
- You removed all children out of a group, and the group auto-deleted itself
